Question about Nikon Coolscan IV ED Film Scanner
I purchased a ge over the stove microwave oven jvm1540. It did not come with a charcoal filter,nobody seems to know what the part is, not even sears whom I purchased it from.It has already cost me 24.00 because I gave the number in the book and it was ordered. Please help
  • 4 Answers
The dimensions of J8x1c is 7 3/4" x 4 7/8" x 3/8" and I doubt this will fit your microwave. You should go to www.rangehoodsfilter.com and custom order one.
Posted on Jul 19, 2009
The above mentioned filter is only the grease filter. For the Charcoal filter do a Google search for part number JX81C. That is the charcoal filter (it was in the instruction manual btw... you should read those).
Posted on Jul 09, 2008
    Guru:
  • 1,342 Answers
What's the right charcoal filter for a jvm1540 ge microwave
o.k if your instr.manual says JX81C you must believe in that. go to www.repairclinic.com and get the parts.
God bless you
Jul 14, 2012 | GE Microwave Ovens
GE Microwave oven JVM1440BH01 vent does not draw fumes from the stove top even though motor is running and air is coming out of the top vent.
Your grease filter or charcoal filter may be clogged.
I would refer you first to the owner's manual, then if everything is set up right, you may need to clean the filter (if it's a grease filter) or if it;s a charcoal filter, it will have to be replaced.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Jan 29, 2010 | GE Microwave Ovens
Where do you install the charcoal filter on spacemaker microwave oven model # jvm1540
remove the two and 3 maybe in the air grill at top of oven . behind inthe center is the filter . ( very pricey // about 60.00 / the make sure it seated properly so the air flow is through filter .. replace front grill and your done .. ****
Jan 09, 2010 | GE Spacemaker JVM1540 Microwave Oven
The Charcoal Filter (JX81C) used for non-vented GE Spacemaker over the stove microwave (JVM1540SM2SS) does not fit anywhere (after pulling off the grill).
This of course assumes that your oven has the optional Recirculating Charcoal Filter Kit (part # JX81C available here) already installed.
From the owner's manual here:
Nov 27, 2009 | GE Spacemaker JVM1540 Microwave Oven
Does this microwave oven use charcoal filters
Hi.
The only time your microwave will use a charcoal filter is if it is mounted over the stove, as a microhood, and discharges into the room, rather than up a stack. If yours is set up as a hood, you'll have the woven grease traps underneath, and the filter will be behind the upper grille.
Best regards, --W/D--
Aug 12, 2009 | GE XL1800 1100 Watts Microwave Oven
I need a charcoal filter
The GE spec sheets for what is the right charcoal filter are incorrect. You will never find the right one. I have this same microwave and had same problem. I called a local appliance company and they gave me Part No. WB06X10359 and when I googled this part it was not the right dimensions. I finally found the perfect solution. Go to www.rangehoodsfilter.com (Filter Factory-TTN Inc.) and they are customing making the filter for me. I spoke to Dave this morning from Filter Facotry and he's making me one with the following dimensions - 5 7/8" x 13 1/4" x 1/4". The cost is $16.95. If this fits I will order more. The more you order, the cost per unit goes down.
Jun 03, 2009 | GE Spacemaker JVM1540 Microwave Oven
Which air filter for GE Spacemaker JVM 1540 over-the-range m/wave
May 25, 2009 | Nikon Coolscan IV ED Film Scanner
Cannot remove the front grill of GE Micro to replace filter
I have a new ge 1540 and needed to remove the grill to install the charcoal filter.
After removing the two screws on top, you need to slide the grill about 1/2" to the left. Then the grill will wiggle loose and can be removed.
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1800 - Noise while heating
Maybe you and the person from the post below could get together and help each other? http://www.fixya.com/ThreadView.aspx?prdid=489218&thid=130453
Mar 25, 2007 | GE JVM1660 Microwave Oven
Nikon Coolscan IV ED Film Scanner Logo
82 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
