Question about Sony Handycam DCR-TRV140E Digital Camcorder
Flashing code C:32:11
The camera was dropped while holding it (30 inches). It appears ok, but when I turned it on, it made a rapid beeping sound and flashed code C:32:10. I turned it off. I tried to eject the tape but it wouldn't eject. No motor sounds. I removed the and re-connected the battery, and it made rumbling sounds from beneath where the tape is. That stopped, and nothing happened. When I turned it off and on again, I received code C:32:11. Repeating on/off, or battery removal causes the same responses noted above. I can't get the tape to eject and don't want to break it. Am hoping there is a user fix. Any suggestions are appreciated. hello.
For no reason my tape won't eject anymore, I hear no motor trying either, it is as though the eject motor is dead. I tried every suggestions in the book: remove batteries, reset button etc... nothing works.
I keep getting error code C:32:11.
I took the camera covers off to see if I could get the tape out, man these cameras are well built, no way in.
Any suggestions?
  • 5 more comments
  • Muuip Jun 03, 2008
    Somehow my comment got mixed with another one, here is my problem below:
    Any suggestions?
    Tried that many times, didn't work.
    Thanks for your answer but I can't find this hole. Are we speaking about the cover which flaps open on top with the "eject" and "reset" button on the inside?
    It is naturally the logical step after trying the basic steps written in the book. Since I don't have a guaranty anymore I was looking for a more advanced technical support. :(
    I couldn't reach under casette door, it is just plastic anyway. So I removed it by unscrewing 2 little screws. Now I see my jammed casette with a metal frame holding it.
    How do I see if motor needs relacement? and where exactly is it?
  • Muuip Jun 04, 2008
    As I opened the cover of the camera I accidentally ripped a cable apart. Camera dead!
    But thanks anyway!
    Genius:
  • 1,447 Answers
Honestly, If reseting and removing battery wont work, send or call technical support if your product is still within warranty. Have a nice day!!
Posted on Jun 03, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jun 04, 2008
    You are welcome and thanks for using FIXYA!!
    Edgar Allan Pagayona Jun 07, 2008
    You are most welcome.. have a good day!!
    Brigadier General:
  • 3,614 Answers
On the lower part of the deck cover, there you will see a hole you can try inserting hard there & gently forced to open the deck..
  • micromaster
    micromaster Jun 03, 2008
    To remove tape, insert proper tool under cassette door and carefully spread brass or plastic slotted door brackets just enough to release it from two opposing pins on the cassette holder.
  • micromaster
    - and for that error the motor is probably bad... check the capstan motor & snd see if it need to be replaced.
    Master:
  • 555 Answers
Remove the battery. Re-attach the battery, and power up the camera. Should retutrn to normal.
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
Olympus VR-340 Won't turn on, lens won't retract.
My camera vr-340, when starts a sound appear and sacreen becomes black . what is this?
Jun 20, 2012 | Olympus Vr-340 16mp Camera Digital Optical...
The Dell 1357 laptop has Vista Home Premium and is as it was purchased. When booting, the computer beeps rapidly for about 30 seconds, displays an opportunity to boot into Vista, and then beeps for another...
If it is actually booting into Vista, it sounds like maybe you have a stuck key. Turn the computer off and press every key a few times and see if any of them feel "stuck". Even if they don't, pressing them may have released any sticking they had. I would try that first.
Jun 24, 2011 | Dell Studio 1537 Laptop
Need to reprogram the code but lost the manual
Hold down the 8 key until 2nd beep sounds. Enter the User Program Security Code. If this code has never been changed enter the default of 1+2+3+4+5+6. When the correct code has been entered the 1st 3 LED's will flash and the sounder will beep rapidly. Press the B/A key and then enter the User Code to be changed (1,2,3, etc.). Enter up to 4 numbers for the new code. Press the B/A key twice to exit the Program Mode. Hope this helps.
May 22, 2010 | Home Security
2005 hyundai accent 1.6L. car won't start
Hyundai TSB 08-BE-012
PROCEDURE:
1. For first time training, press and hold the two outer HomeLink buttons, releasing
only when the HomeLink indicator light begins to flash after 20 seconds.
NOTE: Do not perform this step when training the additional HomeLink buttons.
2. Position the hand-held transmitter 1-3 inches away from the HomeLink mirror,
keeping the HomeLink indicator light in view.
3. Using both hands, simultaneously press and hold both the desired HomeLink button
and the hand held transmitter button.
DO NOT release until the HomeLink indicator light flashes slowly and then rapidly.
When the indicator light flashes rapidly, both buttons may be released. The rapid
flashing indicates successful training and the procedure is complete. This also
indicates that the garage door opener does not use rolling code technology.
Note: The garage door may open or close during this step.
Steps 4 through 7 are only necessary if the HomeLink button appears to be
transmitting after step 3, but the garage door does not operate.
4. Press and hold the trained HomeLink button and observe the indicator light.
If the indicator light is solid/continuous, training is complete and your device should
activate when the HomeLink button is pressed and released.
If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light,
proceed with the following training instructions for a rolling code device. A second
person may make the following steps quicker and easier. It is recommended that a
ladder or similar device be used to obtain access to the motor housing. Do not stand
on the vehicle to perform the next steps.
5. At the garage door opener receiver (motor housing) in the garage, locate the “learn”
or “smart” button (usually near the hanging antenna wire attached to the unit). If
there is difficulty locating the training button, refer to the garage door opener’s
manual.
6. Press and release the “learn” or “smart” button (the name and color of the button
may vary by manufacturer).
NOTE: Once the button is pressed, there are 30 seconds in which to initiate the
next step.
7. Return to the vehicle and firmly press and hold the trained HomeLink button for two
seconds and release. Repeat the “press/hold/release” sequence up to 3 times to
complete the training process. If successful, your garage door should open or close
during this step.
If the vehicle owner continues to have difficulty programming their HomeLink mirror,
please have them contact HomeLink customer service directly at 1-800-355-3515 or
www.homelink.com for further assistance.
PROCEDURE COMPLETE
Dec 06, 2009 | 2005 Hyundai Accent
Flashes turn off and on in the LCD. beep sound
Hello!
Please consider the troubleshooting given below:
(a) Remove the Battery from the Camera then press and hold the power button for 30 seconds.
(b) Reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery pack is fully charged.
(c) Next, try resetting the Camera to the original factory settings if the menu options are accessible on the Camera.
Perform the steps given below to reset the Camera to the original factory settings:
(i) Press the Menu button on the Camera to access the menu options.
(ii) Press the right arrow on the control button to select (Setup) setting, then press the right arrow again.
(iii) Press up/down/left/right arrow to select the Setup 1option.
(iv) Next, select the Initialize Option and select OK.
Performing the above mentioned steps will reset the Camera to the original factory settings.
If the issue persists even after performing the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Not able to shoot photos
OK, I have this camera and it started doing this to me about a week ago.  I assumed it had reached the end of it's life after many, many excellent photos.  As a last resort when the lens popped out after first switch on (when it's doing the clicking business) I grabbed the lens and wiggled it gently back and forth (as if zooming a conventional SLR).  It appears to have been fixed, remarkably!  I switched off and switched it back on and all seems OK.  (I'm not holding my breath and will probably keep looking for a new one but for the moment it's sorted out.)
Mar 17, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
USE THE MAINS ADAPTER....TAKE THE BATTERY OUT, AND CONNECT MAINS ADAPTER THEN IT SHOULD WORK THEN TRY EJECTING THE TAPE AGAIN
Feb 23, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
Camera rapidly beeps 6 times when powered up and immediately turns off!
I HAVE SOLVED THIS!
I Totally fixed my CAMERA!
If you turn on your camera, the lens does not come out, and it just beeps then turns off, then listen to me.
You need to unscrew the outer casing and take off the metal shell.
Hold the camera in one hand, palming it, looking down at the LCD (ie the lens is pointing into your palm). This is to orient you.
If you look at the left SIDE of the camera, near the upper left corner of the LCD, you can peek through some of the windows of the black plastic casing and see 2 PLASTIC GEARS. The top one is white, the other is black. These are the gears that actually move the lens in and out. All I did was give the white gear a good jiggle with the tip of a pen and evidently it made the teeth of the gears mesh together like its supposed to and .... VOILA .... the lens came out when I powered it on and all is well! I know this is gonna help someone!
Dec 18, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Sony Handycam DCR-TRV140E Digital Camcorder Logo
379 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
