Sony Net MD Walkman MZ-N510 MiniDisc Recorder Logo
Posted on Jun 03, 2008
Te record with a microphone
Hello sir,
I have a EM35 Vivanco mic. and want to record my own voice, but I can only hear a very soft sound. The battery is ok. I put the volume of the mine disc record on max, but still the sound is poor. How can i get a better result.
please let me know
thanx Ton de Graaf my e-mail adress is [email protected]
Anonymous
Level 1:
  • Contributor 27 Answers
  • Posted on Jun 13, 2008
Anonymous
Contributor
Level 1:
Answers
27
Questions
Helped
11591
Points
28
Please post more information about the recorder you are using.
2answers
Dose'nt work
email the company you purchased from
1helpful
Hello. I have an aspire acer 5732ZG T4500 laptop. and I just made a chat several day without a jack. and one day all this chat never goes out unles i use a mic jack. when I go to the store I bought it,...
For your model I've checked and there is no onboard microphone, and there is no way you can record your voice or is able to send voice chat unless you have an external microphone, or a external webcam that provide with a microphone in order for you to record or do a voice chat. Now if you cliam that you were able to do a voice chat, and someone was able to hear you or able to record voices.... Then i would only guess that in your sound device, you probraly disabled the microphone it or lowered the microphone volume. You can check this out by going to the little sound icon on your right taskbar, double click it, and on top of the bar, there is a speaker icon, press this and a window would pop up, you would want to go into the "level" tab and see if the microphone option has been muted or lowered. If everything is enabled and working.... I don't know about your mystery since your model spec does specify that there is no onboard mircophone.
1helpful
Whistling background noise with Samson C01U USB condenser mic
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
23helpful
5answers
Audio on Dell Webcam Central And voice record isn't working
I have a Dell 1545 with Dell web cam central & I've had this issue. The problem is that Dell web cam central installs it's own microphone settings onto your laptop called something like Dell web cam Live!. This isn't the built in microphone in my laptop & maybe not yours either. You have to change the settings for your computer system & Dell web cam central. Go to start> control panel> sound> recording .. on mine there is an option for Microphone "High Definition Audio Device" ... that is the built in mic. You want that for your default & apply it. Also .. as a side note .. I disabled the web cam central Live! microphone completely from this window. Then open Dell web cam central & go to the "Record Video's" option. In the middle of this is an orange button with a video camera icon. Next to this on the same button is a little arrow pointing down .. click that. Under microphone .. choose Microphone "High Definition Audio Device" just like the sound option in control panel. I've done this & it's completely fixed. I can record videos with sound & use my built in mic in voice/video chat.
How to hear my voice through my usb microphone?
double click on the volume icon on teh right hand bottom corner,& check whether the microphone option is muted or not
Microphone and headphone problem
Usually when you double click the speaker icon in the system tray you'll see the volume settings for all your devices. On microphone there is usually an check box for mic boost. Set those to mic boost. Then check that all the sliders in the volumes are one increment below the top but maximum for Wave. Then set the master volume to a comfortable loudness This you can access by a single click to the speaker icon.
Next, you can go to Control Box, click on Sounds and check the settings for speakers/headphone and also for recording where there is usually a routine for checking the recording settings via your microphone made available to you.
Please do not hesitate to ask me for more information and kindly be specific if you can. I'm here to help and will get back to you in a reasonable period of time.
Hope this fixed your problem and thanks for using Fixya.
Regards,
Worldvet
1helpful
by default the playback of your voice is muted. next to your clock theres the sound speaker icon click on it, you should see microphone somewhere there, if you dont press settings from the toolbar and then properties
then on the playback make sure there is a X on microphone.
then click ok, now check is the microphone muted? unmute it and speak to the microphone you should hear your own voice played back instantly from the speakers.
2helpful
My computer is not detecting microphone when making internet phone calls.
Troubleshooting - Can't get voice chat to work.
Here are a few things you should know and check for to get the voice chat to work. · Firewalls - the voice chat feature may not work well behind company firewalls. Even though you can get other features of Yahoo! Messenger to work, the voice chat feature uses separate technology and may not work as well.
· Check connection - When you enter into a voice chat with friends, each participant should take turns trying to press and hold down the Press to Talk button. Everyone else should see their name turn red when they do that. If you see their names turn red, but don't hear anything, it may be a microphone / speaker problem, or it may be that we have more bugs that we need to fix. If you don't see their name turn red, you are probably having connection problems and that's why it's not working.
· Get the latest version - Please make sure that everyone who is using the voice chat feature has the latest version.
· Check mic and speakers - Check that your microphone works and that your speakers are turned on. Here's how:
* make sure the mic is plugged in correctly.
* adjust the mic properties.
- go to the control panel (start button -- settings -- control panel)
- click on the multimedia icon
- you should see a tab for audio
- make sure that the recording volume is set high.
* you can test your mic. by doing the following.
- Click the Windows Start button, then go to Programs, then Accessories, then Multimedia, then click on Sound Recorder
- A new window called Sound Recorder will pop up. Click on the record button (a red circle), then say a few words, then click the stop button (black square).
- Click the play button (black triangle).
If you can hear yourself fine, then your microphone is okay. If you can't hear your voice using Sound Recorder, the voice chat should not work either.
About my mic.
go to control panel:-1-select-sound and audio devices.2-select audio3-in sound recording select your audio driver{creative or other}3-press volume you will see capture screen raise mic volume above and select check box under it.===enjoy recording.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
