Question about GE Kitchen Ranges
Is a oven soppose to beep when it is finishing a self cleaning cycle? the model number is jsp39wokiww
    Scholar:
  • 196 Answers
Depending on the model number the answer can be yes. Some models have countdown clocks that beep to let you know that the process is complete.
Posted on Jun 04, 2008
My Kenmore Range Model #95014 is displaying an E1 F5 error and will NOT unlock!
This error code has to do with the oven door lock assembly.
What is the complete model number listed on the unit? Look in the door area or the storage area on the bottom if you have one.
Dec 08, 2012 | Kenmore 95012 / 95014 Electric Kitchen...
Frigidaire smooth top electric range flashes f9 after cleaning
The "F9" error code means the EOC (electronic oven control) has found the lock motor switches to be out of sequence or shorted.
Test switches and if there is nothing wrong then replace the EOC.
What is the model number?
Nov 28, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How do I start the self cleaning? I hit clean and it does not start
On most self-cleaning ovens after you push the clean cycle button you have to tell it how long you want it to clean. Try pushing clean then pushing 3:00 for 3 hrs. If you don't have a number pad try pushing the clean pad several times and see if it cycles through clean levels like low, med or high. Then after you tell it how long to clean hit start. If you don't have a start button the oven should start cleaning after around 5 seconds. It will lock the door and begin the clean cycle. Also remember it takes around an hour for the oven to cool and unlock after the cycle is finished. Hope that helps.
Aug 29, 2011 | GE JKP45 Electric Double Oven
Cant get the oven to turn off from the cleaning setting and its just making a loud beeping sound, had to unplug.
After unplugging, allow the oven cooling down for few hours.
If the beeping restart, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Frigidaire at the number listed on the owners manual.
Regards.
Mar 02, 2010 | Frigidaire Gallery 30" Self-Cleaning...
Using the oven self cleaning cycle to clean drip
This is not advisable because it will severely damage the chrome and or color of the drip pans and the oven racks. It will make the oven racks hard to pull in and out of the oven once the finish has been burned off. I did this, so I know.
Nov 11, 2009 | Kitchen Ranges
Oven lock will not open
my self cleaning oven door will not unlock what do I need to do?
Jan 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
How does self clean work
MOST SELF-CLEAN OVENS RAISE THE TEMPERATURE IN THE OVEN TO ABOUT 850 DEGREES AND BURN EVERYTHING TO A POWDER. THAT IS WHY THERE IS A SPECIAL DOOR GASKET AND IMPROVED INSULATION AROUND THE OVEN LINER. THE AVERAGE CLEAN CYCLE
TAKES 3 HOURS TO COMPLETE. YOU SHOULD BE ABLE TO
LOCK THE OVEN DOOR (SOME MODELS LOCK THE DOOR
AUTOMATICALLY) SELECT SELF-CLEAN, AND START.
OLDER MODELS WITH A MECHANICAL TIMER AND CLOCK REQUIRE SETTING THE START AND STOP TIME.
Aug 01, 2008 | Maytag Kitchen Ranges
Self cleaning
You can go to the Maytag web site and download the manual.  www.maytag.com, or go to http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
and download the manual CAUTION
• It is normal for parts of the ovens to become hot during a self-clean cycle.
• To prevent damage to oven doors, do not attempt to open the doors when LOCK is displayed.
• Avoid touching doors, windows or oven vent area during
a clean cycle.
Do not use commercial oven cleaners on the oven finish or around any part of the ovens.  They will damage the finish or parts.
Do not leave baking/pizza stone in the oven during self-clean.
The self-clean cycle uses above-normal cooking temperatures
to automatically clean the oven interior.
The oven should be cleaned regularly by wiping up spillovers
to prevent excessive smoke and flare-ups.  Do not allow a
heavy build-up of soil to accumulate in the oven.
During the cleaning process, the kitchen should be well
ventilated to get rid of normal odors associated with cleaning.
Before Self-Cleaning
1. Turn off the oven light before cleaning as the light may burn out during the clean cycle.
2. Remove broiler pan, all pans, and oven racks from the oven.  The oven racks will discolor and may not slide easily after a self-clean cycle if they are not removed.
3. Clean oven frame, door frame (area outside of gasket, and around the opening in the door gasket) with a nonabrasive
cleaner such as Bon Ami* or detergent and water.  The self-cleaning process does not clean these areas.  They should be cleaned to prevent soil from baking on during the clean
cycle.  (The gasket is the seal around the oven door and window.)
4. To prevent damage, do not clean or rub the gasket around the oven door.  The gasket is designed to seal in heat during the clean cycle.
5. Wipe up excess grease or spillovers from the oven bottom. This prevents excessive smoking, flare-ups or flaming during the clean cycle.
6. Wipe up sugary and acidic spillovers such as sweet potatoes, tomato, or milk-based sauces. Porcelain enamel is acid-resistant, not acid-proof.  The porcelain finish may discolor if acidic or sugary spills are not wiped up before a self-clean cycle.
Important:
• Oven temperature must be below 400° F to program a clean cycle.
Only one oven can be cleaned at a time.
• Both oven doors lock when either oven is being cleaned.
To set Self-Clean:
1. Close the oven door.
2. Press the Clean pad.
    • CLEAN flashes.
    • SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
    • “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning settings.
     “HVy” (Heavy Soil, 4 hours)
     “MEd” (Medium soil, 3 hours)
     “LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs the self-cleaning time.
5. After four seconds, the oven will start cleaning.
    • If the door is not closed, beeps will sound and ‘door’ will display.         If the door is not closed within 30 seconds, the self-cleaning       operation will be canceled and the display will return to the time of day.
    • CLEAN will appear in the display.
    • LOCK will flash in the display.  Once the door locks, LOCK will
      remain steady.
    • The cleaning time will start counting down in the display.
Nov 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
