Question about Lakewood 16" Stand Fan
Lakewood 16" Pedestal Fan- Control Switch gone bad (probably)-
Similiar problem on my 16" Lakewood Pedestal Fan, Model 1645-DX.
The control switch has probably gone bad, but it is not so straightforward as to getting the plastic motor cover removed to expose the switch. One Philips head screw loosens the plastic cover, but the cover remains "captured" by the "Push-pull Knob" which engages the oscillator gear (box) attached to the end of the motor (shaft). The Push-pull Knob does not seem to detach by "unscrewing." It can be rotated freely, which doesn't remove it. As these components are molded plastic, but are not "fiberglass" strengthened, I'm hesitant to apply much force on the mechanism.
Presently with this Fan (to repair), I'm "stimied," and will appreciate any help you can give. Jim W.
    Scholar:
  • 79 Answers
I have seen a number of oscillating fans where the push-pull knob just pulls off. It will require a serious pulling effort - straight up. Do Not use any tools. You may have to have a helper hold the fan while you pull the knob.
After the knob comes off, push the shaft back down with your finger to allow it to clear the housing.
Posted on Jun 11, 2008
Need to find the pull chain switch to replace. where can i buy it? for the hv 30pb
mcdevito75 here, You may be able to match up the factory switch with a switch from a large hardware store, home depot, etc. or you could try to contact your fans maker plus.com nline.
Jul 21, 2010 | Lakewood HV-30PB Stand (Pedestal) Fan
Lakewood heater 792 will not work
The bottom switch is bad. Unplug bottom wires and touch them together, if heat and fan comes on your switch is bad.
Feb 11, 2010 | Lakewood 792/JR Utility Heater
Model #70001A controll switch melted
you can go to this web site to purchase a new control board. You will need to test the heater element to make sure that it's not shorted to ground. If you need more help with this just respond to the e-mail you receive also be sure it is unplugged before testing and short out the end of the plug if it's not hard wired into the wall. here's the site.
http://www.officeworld.com/-/70001a-lakewood-heater
Jan 27, 2010 | Lakewood Heating & Cooling
My Lasko Pedestal fan just stopped working completely
Its probably something simple, plug it into another outlet and make sure that outlet work also, if that dont work it will be in the control switch and i doubt the motor is burnt up. You can take srew driver and open up the control cover to see if there a fuse and check the wiring connection from the outlet to the control switch and make sure the fan is unplug before you open up the cover. Jiggle the wire inside the control unit than press and play with the button couple of time and plug it back into the outlet and see that will work. if not than have somone test the the motor with a volt meter making sure the motor still good. I believe it be more likely in the control swith unit. hope that work for ya
Jul 10, 2009 | Honeywell HFS641P Stand (Pedestal) Fan
Speed indicators light up but no fan operation 18" floor fan.
Your fan speed control module is probably shorted and is damaged. Have it repaired by an electrician.
May 01, 2009 | Lakewood HV 18-c Floor / Box Fan
Need to replace the switch that has ,hi,low,med off on nit? please Help
you have 3 control wires (the 3 speeds) and a common wire. the common wire will go directly from the fan motor to the power source/cord and the other 3 leads will run through the switch. you could even use a standard dimmer-style lighting rheostat and connect it to the common and "high" fan speed wire and have infinitely variable fan speeds. hope that helps.
Apr 30, 2009 | Lakewood HV-18 Floor / Box Fan
To repair 18" lakewood stand fan mod.#HV-18-p
unplug the fan!
1 remove the six screws that hold the front grille on.
2 use an allen wrench to loosen the screw that secures the fan blade assembly to the motor shaft. (screw is between the blades and the motor and it is on tight, make sure that you do not bend the fan blades, this would cause balance problems)
3 remove blade
4 you will now have access to the screws that hold the motor cover in place.
5. when reassembling make sure that the strain relief (or knot in the cord on some models) is inside the motor cover, and that wires are not being pinched.
6. Good luck
Mar 06, 2008 | Lakewood 16" Stand Fan
Window Fan switch bad
Steve, Your fan model is HV-18-WR; I have 2 with the same problem. I can't find a source for DYE-3606 switches either. Here is one source for rotary switches; one might be suitable: http://www.alliedelec.com/Catalog/Indices/Products.asp?sid=46BBAA8076DBE17F&N=4294828748 I can draw a diagram of how the existing switch is connected, but I don't know how that would translate to a replacement switch.
May 22, 2007 | Lakewood HV12WR Window Mount Fan
Lakewood 16" Stand Fan Logo
377 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
