Question about Philips 42FD9954 42 in. Plasma HDTV
42" Philips plasma screen goes black
My Philips 42" plasma tv screen often goes black, sometimes only the bottom half. When I tap the side of the set, the full picture returns but the problem returns...... any advice/suggestions?
  • 3 more comments
  • larkspurboy Jun 10, 2008
    I have the same problem with my 42in. but it has been going on for months. I thought it had something to do with my directv receiver but i guess not. half the picture comes and goes only lower half goes out. sometimes stays out for 10-15 seconds then picture returns but has been happening more frequently. any suggestions
  • Innovator Jun 12, 2008
    I also had the same problem with my 42" Philips Plasma Tv for several weeks, but now the picture quality (regardless of input) has become grainy with 3" horizontal bands. The picture is too bad to watch at this point. Any suggestions on where to look for the problem on the inside after I take it apart? How much do you suspect a repair shop will charge to trouble shoot the problem and R&R the bad part(s) if they can find the problem?
  •  ForeverFenis
    ForeverFenis Jul 31, 2012
    i believe next time i concider buying philips i should take my cash out of my wallet carefully place it on the side walk and **** ON IT!
  • Anonymous Mar 25, 2014
    Dell 42 plasma top half screen intermittent no video
    There is a slight burning smell
    Problem Solver:
  • 7 Answers
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Posted on Jun 07, 2008
My LG 42 Plasma works sometimes then half the screen goes black but the right side stays perfect???
have almost the same problem left side is black with sometime blue line red lines or a whole bunch of different lines some one help please have sound and right side of tv works fine
Sep 26, 2010 | LG 42PC3D 42 in. Plasma Television
While watching tv half the screen goes black
Download software from the Phillips web site. Use a usb flashdrive to transfer the download to the TV. This worked well for us and our picture is better than ever.
Apr 09, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Picture goes black on bottom half of the screen
You have a bad connection to the panel or bad caps on the boards. Not something for the DIY'er. High voltages in plasma sets.
Mar 31, 2010 | Sanyo DP42746 42 in. Plasma Television
My plasma screen goes black on bottom 1/2 of the screen
In most cases the lower Y-Buffer board causes this issue. Unless you know how to work on a TV it is suggested that you have a technician look at the TV and repair it for you.
Nov 05, 2009 | Philips Magnavox 42MF521D/37 Television
Bottom half of screen is black
its ur diaplay problem.. go for a change of new display...
Jun 30, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips 42 inch Plasma -Screen Issues!!!
intermittent loss of picture on either bottom or top half of screen is specific to y buffer boards located on left side of screen going from top to bottom when looking at back of tv. the y lower buffer would be the board to replace to resolve the loss of bottom half of picture. if the top half also is going out intermittently could tied to upper buffer as well but just a note the y main board to right of these buffers drives those two boards so in some cases could also be part of the problem. if only bottom half is affected i would recommend replacing lower buffer only
Aug 07, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Samsung PS42S5hX - Bottom half of screen flashing black sometimes permanent, does not do this all the time.
might be y drive board bottom half it connects to the y sus board usually on the left side if your looking at the set with the back off
May 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Philips 42FD9954 42 in. Plasma HDTV Logo
807 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
