Question about Sony MHC-GX450 CD Shelf System
Volume control The volume control which is the round part is loose. For example if i turn the volume higher, it keeps spinning and spinning. Is not as tight as it was before. Also the other part of the roud thing so you can switch songs is loose.
There's not really anything you can do to fix that
Posted on Jun 04, 2008
I bought the rca rt2781de MDL when I adjust the speaker loudness and turn the unit off and turn it back on my adjustment settings are lost
I'm going to guess and say that your volume control turns round and round, but never stops like the old volume controls. Correct? That is because it is a Rotary Controller(an input to the microprocessor, computer inside inside your unit) These are known bad parts.
The issue of loosing the memory when turned on and off, is most likely due to a bad backup capacitor. The manufactures used to use batteries(on the back of the unit) but that was done away with 2 decades ago. If you require more assistance, or would like to inquire about repairing your RCA, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Dec 30, 2014 | RCA Audio Players & Recorders
Need to tighten volume knob on my connex 4300hp
I'm assuming you mean just the knob, and not the shaft behind it, if it's a D shaped shaft, a slip of paper in the knob will tighten it up, if it's knurled and round shaft, spread the split in the middle open slightly until the knob is tight
Feb 11, 2014 | Connex Radio Communications
On my sr606 receiver when I hook up the hdmi to the tv i sporadically loose the signal. when I hook the cable box to the tv it is ok. there seems to be a problem with the hdmi interface
Try this. Check to see if you have the cable going round and accute corners. Sometimes the placing of HDMI sockets on the unit mean that the cable is forced into a sharp turn to route it to the cable box. HDMI cable is touchy when it comes to routing. For example an HDMI cable coming out the side of a TV and having to do an immediate 90 degree turn to get to the cable box is enough to scramble the signal. HDMI cable must not be kinked, wound up tightly or forced into tight angles. The worst offenders for this are curiously the more expensive cable as they have a tougher outer shielding that makes them more prone to situations in cramped and tight corners. If you really need to get round a tight corner, try a cheaper cable. Hope this helps
Mar 15, 2011 | Samsung Audio Players & Recorders
THE VOLUME DIAL (LARGE ROUND WHEEL) DOES NOT WORK PROPERLY. You turn it clockwise to get higher volume, the digital numbers go lower, higher, and not the way it should be. The volume doesn't increase or...
Some tuners denote volume as attenuation so zero means it is at full volume and -20 means it is 20 decibels or 20 percent etc below zero. Essentially, zero means it is not being held back while the higher the number, the higher amount of holding back.
I am not sure what you mean by the volume does not increase or decrease normally so you'll have to ask that one with more details and information to get something more on that issue.
Jan 17, 2018 | Sony CMT-HPX9 CD Shelf System
The shaft piece on my hobbylock 786 serger is loose
The top hex screw I think holds the bushing that allows it to slide freely. Keep that loose. If you open the panel where the lightbulb lives and spin the wheel, you will see a small flathead screw come into sight near the top of the rotation, through a small round window in the case. Tightening this screw a bit should keep the needleshaft moving with the wheel. Unfortunately I am still trying to find out how to position it so that it's properly timed.
Jan 20, 2010 | PfaFF Sewing Machines
My 2000 323 shakes REALLY BAD (sometimes) when I driving down the highway...it stopped for a month, but recently started again. It shakes so bad, its as if the wheels are about to fall off (very scary)...
Have you checked for lug nut tightness? Any loose component in the steering or suspension? Jack up each wheel and wiggle it to look for looseness. Spin the wheel to check for wheel and tire roundness--listen for grinding noises. This is a problem that you shouldn't ignore as it could lead to losing control completely.
Oct 19, 2009 | 1999 BMW 323 Series
I have a stx38 riding lawnmower. The drive is herky jerky in forw
I have seen this problem on other tractors. It is caused by a loose or sticking drive belt between the engine drive pulley and the transmission. There is an idler pulley between them that is spring loaded to keep the belt tight. If the pulley bearings froze so the pulley doesn't spin, or if rust or a broken spring prevents the pulley from swinging over enough to keep the belt tight it would cause the problem.
May 05, 2009 | John Deere Garden
Bernina 180 Bobbin case spinning
Its called the bobbin stopper. Pop off your needle plate by pressing on the marked corner. In the back on the left you will see a small allen screw which must have come loose. Position the bobbin stopper in place and tighten that screw. If it already is tight, loosen it and reposition the bobbin stopper in the notch and tighten it back up.
Good luck.
Oct 04, 2008 | Bernina Artista 180
Tensioner
yes it keeps the belt tight so it can turn the drum. its like a pulley that keeps the tension on the belt so that the tub can spin etc.is the belt tight now or is it loose?
Aug 11, 2008 | Dryers
Kenmore h3 won't spin
Remove the pulley nut and pulley. The pulley should have a round hole with two flat sides that ride on a shaft. If the flat sides of this opening are damaged the pulley will not stay tight and will rattle. Try tightening everything down. If you can grab the pulley (like a steering wheel on a car) and turn it back and forth on the shaft, there shouldn't be any "play" in it. The whole drum should turn. If this is the case, replace the pulley and nut. I hope this helps you.
Jul 31, 2007 | Kenmore Elite 45986 Front Load Washer
Sony MHC-GX450 CD Shelf System Logo
61 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
