Question about Westinghouse Turbo Swirl 78145 Ceiling Fan
Zing ear rotary switch
Rotary switch with 3 wires, red, blue, and black. i need to know which to connect where to standard ceiling light wiring.
miguel1017
SOURCE: trying to replace 3 speed
Hi
The pull switch has 4 wires, L, 1, 2, 3.
Connect ' L' to the reverse switch red wire or the wire that is free.
Connect ' 3 ' to the main black ( hot ) wire entering the fan.
Connect ' 1 ' to the capacitor's lowest uF eg. ( 1.5 uF )
Connect ' 2 ' to the capacitor's next uF eg. ( 3 uF )
the Capaciotr also has to be connected to the neutral wire entering the fan, usually black attached to another color wire. If you have a VOM tester, veryfy that it is a neutral wire.
Regards
H. Montero
Posted on Apr 17, 2009
  • 4 Answers
SOURCE: how to wire a ceiling fan
What you need to do is take the plate off at the switch on the wall. There shoulld be black wires and white wires. Attach a resistant tester to the white wires, and connect a long wire to the other probe of the tester. then touch the long wire to one of the black wires at the ceiling. If you are lucky, you might get the right black one on the first try. If not, touch the other black one, and that should be the white wire. Have the electric off to test this. When you find which is the white, or common, read the instruction manual and see which of the brown or greenyellow is designated white. I think these colored wires are at the bottom where the lights connect. At the top of the fan should be a white, blue, black and green wire. The Black wire from the ceiling will attach to the hot black and blue for the lights of the fan. The black wire which you discover to be actually white from the switch should be connectied to the white wire of the fan at the top. The red wire sometimes is used to connect to the blue wire so that you have a switch at the wall for the light and one for the fan. That is an old way of wiring fans. Joe
Posted on Jun 29, 2009
  • 34 Answers
SOURCE: i have a black, white, red and a bare wire in the
black goes to black. white goes to white. red goes to blue. there should also be a green wire attached to the fan near where the other wires come out, if you do it attaches to the bare wire
Posted on Sep 09, 2009
SOURCE: trying to install a westinghouse ceiling fan into
NO NO NO..... Blue is Neutral...
BLACK is PHASE, BROWN is PHASE, RED is PHASE
WHITE is NEUTRAL, BLUE is NEUTRAL
Green, Green/Yellow is EARTH
Posted on Feb 21, 2010
  • 101 Answers
SOURCE: zing ear switch from a hampton bay ceiling
Did you try Home Depot, Lowes, or any lighting supply store. It's a pretty common item, so they should all stock it
Posted on Apr 07, 2010
How do i wire a 3 speed zing ear ceiling fan switch 208s with purple, yellow and gray wires?
First, is this the correct switch? Do you know the make/model of fan? No black wire? fanman9952@aol.com
Mar 15, 2015 | Dryers
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
Feb 18, 2013 | Hampton Bay 24750 Huntington III Ceiling...
Where can I find a replacement switch. Zing Ear ZE-268S6. Thank you.
Hi Eric...
Click here Amazon com zing ear switch and chose the best one for you. Anyway contact the seller before buying, to see if fits on your model. I hope this helped.
enjoy
Jun 27, 2011 | Hunter Ceiling Fan Light Switch Control
Need to know how to wire this fan. Not using a remote or wall switch
Hello! W/D here.
In your ceiling box, you'll find 3 wires; black, white and bare copper.
In your fan, you'll see 4 wires; black (or red), white blue, and green.
With your breaker tripped, connect the green wire on the fan to the bare wire in the ceiling (this is your ground).
Connect the white fan wire to the white ceiling wire (this is your common).
Connect the blue and black (or red) together, and connect these to the black wire in the ceiling (this is the hot lead, and will supply power to the fan and the light).
Best regards, --W/D--
Feb 13, 2011 | Westinghouse 78500 Casanova White Ceiling...
Hi. My name is Nivardo, I’m from México and
In the base of the lamp, cut the 2 wires coming in from the wall.
On one wire from the wall, connect it to the same wire going to the lamp (white wire, if you can tell which is which), AND the white wire from the Zing Ear (3 wires connected together).
For the other wire from the wall, connect it to the BLACK wire from the Zing Ear.
For the remaining wire to the lamp, connect it to the RED wire from the Zing Ear.
You also need to fasten the "TOUCH" wire from the zing ear to the frame of the lamp -- the metal part where you would touch the lamp.
That should do it.
Jun 11, 2017 | Hampton Bay 52 In.Carriage House II in...
3-speed fan switch broke on Hunter model 28072, cat. 300 fan. Found replacement switch at Lowes, but wiring colors are completely different from manual. What color wires go into L, 1, 2, 3 positions...
My Hunter fan uses a Zing-Ear ZE-268S6 switch. This is NOT a standard switch! It connects L to 2 AND 3 for medium speed. It is best to order the exact switch if possible. Hunter wants to sell you the entire bottom assembly (probably expensive). I found the exact switch online at:
http://www.kenselectronics.com/lists/switches.htm#Pull%20chain
for $6.80 plus $4.95 shipping. I bought an extra which didn't increase the shipping - worked great. Hunter ZE-268S6 ceiling fan connection colors: L=black; 3=green; 1=grey; 2=brown. If you need a different switch on their page, just click the Edit menu, then Find, type your part number in the box, and click Next.
Nov 30, 2010 | Hunter Ceiling Fan Control Switch
Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
May 24, 2010 | Westinghouse Electric Westinghouse...
Zing ear switch from a hampton bay ceiling
Dec 12, 2009 | Hampton Bay 52 In.Carriage House II in...
Ceiling Fan Light Chain Broken; Zing Ear
It's actually a very easy repair. Those pull chain switches are very generic and can be found at home depot or any hardware store for about $3. As far as changing the switch there are only 2 wires to connect and there is no incorrect combination to reconnect them.
Sep 03, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Westinghouse Turbo Swirl 78145 Ceiling Fan Logo
668 people viewed this question
Top Westinghouse Dryers Experts
stevensmn
Level 1 Expert
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
