Question about Whirlpool Kitchen Ranges
I have a whirlpool stove GLP8580 self clean lock just keeps going back and forth when you press clean botton
  • harryhwd Jun 03, 2008
    I set the timing push the clean setting the light keeps flashing on off and the lock part keeps clicking back and forth quite loud.If I pull the door out a bit sum time it will stop and start clean and working okay.And the next time I try it will stat clicking again and wont work.
    Genius:
  • 1,447 Answers
Check if the lock lever is set or switch to clean when pressing on the clean button, make sure its all the way to the clean position.
Posted on Jun 03, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jun 03, 2008
    clean button should lit on when lock lever is positioned all the way to the right, securely close the door and that will do it.
    Guru:
  • 1,342 Answers
Try pushing the door in when you press the clean button.
Appliance Repair Clinic
    Brigadier General:
  • 3,614 Answers
The unit self clean was lock and you have no control to stop it..?
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
FSE1 CODE just popped up on the stove and the latch started going back and forth and the interior light would go on and off. We weren't even using the stove or oven when this happened. What does
The F5 E1 error message indicates the latch motor was unable to lock the door. When the self clean cycle is started, the control board will turn on the latch motor which is mounted on the rear of this range. The motor is connected to a cam that transfers the motors motion to a rod that runs under the cook-top. Here is the part to order.
Dec 10, 2012 | Whirlpool GR460 Electric Kitchen Range
Lost Manual and would like instruction on how to set for self clean cycle?
Make sure you have everything out of the oven, including the oven racks.
1. Press SELF CLEAN.
2. Press the TEMP/TIME "+" or "-" arrow pads to enter the desired self-clean cycle.
3. Press START.
The oven door will automatically lock. The DOOR LOCKED and CLEAN indicator lights will be
displayed.
4. When the self-clean cycle is complete and the oven cools, the DOOR LOCKED and CLEAN
indicator lights will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth.
Recommended times are 2 hours 30 minutes for light soil and 4 hours 30 minutes for heavy soil.
If your oven has a HI and LO self clean time, HI is 4 hours 30 minutes and LO is 3 hours 30 minutes.
It is also recommended that you remove anything plastic from the top of the stove during cleaning.
Nov 27, 2010 | Whirlpool RF263LXTQ Range
Whirlpool self clean GGP84803 door won't lock when initialized.It is clicking and diplays locked but I can still open door?
If the lock will not engage and keeps locking and unlocking then turn the power off, slide the stove out to obtain access to its back. Remove the 3 screws from back cover and you will see the locking motor and a switch with a lever that rests on the locking rod. This lever has lost its firmness and does not engage the switch to tell the motor it is locked. Simply take a pair of pliers and bend the lever down to put more load on the lever. Now when the rod turns it will fully engage the switch which will tell the motor that the door is locked. Test your setting to make sure you have it adjusted right and then re-install your cover and push your stove back into position and enjoy your day. Takes 10 to 15 minutes and is cheaper than calling a service tech. Remember to turn the power off when working on the back of the stove through testing and such. No need to get hurt.
Jul 02, 2010 | Whirlpool Ovens
Kenmore Electric Range model 790 has F9 & F1 code error
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 20, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My oven code is F5E1 , my oven was in self clean , now the door is locked
F5E1 is door latch assembly. One way that may work to unlock is to turn circuit breaker to stove off for few seconds then turn back on and door lock should activate and unlock. If not you are going to have to replace the door lock assembly.
Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Touch pad will not unlock after running self clean cycle,
ran the SCC and the oven door unlocked when completed but the touchpad did not. Can;t use over at all, top of stove works fine. None of the bottons for the oven works. still says self clean completed, will not go away, can't use oven at all.
Dec 14, 2009 | KitchenAid KESC307 Electric Kitchen Range
Door will not unlock after self clean.
It's probably the timer motor which is stuck. unplug the range!! I recently had the same problem with my whirlpool (hereinafter known as **** inc.) range. Self cleaned the oven and then the door wouldn't open. Googled up similar problems and generally found out that ****inc. had this problem on both gas and electric ranges and it costs an arm and a leg for a new board plus labor. Found out how to manually open door with coat hanger but of course still had problem with same error messages; also the oven, clock, etc wouldn't function. Took the cover off the back of the stove. UNPLUG THE STOVE On the left rear facing the back of the range he found the timer motor had stopped.He unplugged input(230 volt power) leading to the stove, then unplugged and insulated the wiring to the timer motor and the microswitch on top of it ( 4 wires). Then he took the long steel wire off of it and unlatched the oven door. Told me that this probably had something to do with the timer motor on the self cleaning cycle and that it was stuck Said this whole thing could probably be fixed with a bit of WD40. Said probably nothing wrong with board but it sure must be a moneymaker for **** inc. The service techs probably clean the timer motor, say they changed the $300 board, and go on their way. Plugged stove back up and voila! Everything worked except self cleaning function. Hope this helps someone. caution!!!! Do NOT use the self cleaning function unless you fix the timer motor. Replace it or clean it.
Nov 21, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Amana stove stuck in 'lock' mode, door won't open
try hitting cancel is it displaying any error codes like e2 f3 try turning the breaker for five seconds then back on
Dec 28, 2007 | Whirlpool RF378 Electric Kitchen Range
Kitchen Ranges Logo
74 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
