Question about Emerson EWC1902 19 in. TV/VCR Combo
HOW DO I SWITCH FROM CATV TO REGULAR ANTENNA IN THE MENU?
CANT SETUP CHANNELS FOR REG ANTENNA, CANT SWITCH FROM CATV
  • ornchfrog Jun 07, 2008
    cannot select that option
    New Friend:
There is nothing on the set up menu that says care or antenna. so now what can I do?
Posted on Oct 09, 2016
  • 31 Answers
In the Setup menu there is an option to specify if you use an antenna or cable. Just switch it to antenna.
Posted on Jun 03, 2008
Not getting all the channels- only 2 - 13 and auto set isn't finding the others. Apreciate any help.
Look in the setup menu, set is now set to air or antenna which on cable will only allow channels 2-13------------if on cable or such switch the setting to catv/cable and not to air/antenna.
Dec 21, 2012 | Televison & Video
A 96 model : 16-422 is stuck in HRC or IRC and we cannot manouver thru menu to change it back to CATV
HRC/IRC is CATV
Who is the manufacturer and Model ?
Older Sharp sets had a switch on the back near Antenna in.
Other sets have a "setup" in the menu that will let you navigate further to hooking up the TV.
Oct 20, 2010 | Televison & Video
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
Trouble with Channel setup
It is important for the TV to know what type of
signal-Cable TV (CATV) or a normal antenna
you are using. Choose your signal (Antenna or
Cable):
Press MENU to see the main menu.
Press CH+ or CH- to highlight Setup.
Press OK
to enter the Setup submenu.
TV/CATV is highlighted. Press VOL+ or
VOL-
to select TV or CATV.
Choose CATV if you have Cable TV
service. (See page 4 for connection
details.) If you do not have Cable TV
service and you connected an antenna
to the TV, choose TV. (See page 5 for
connection details.)
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
And here is the manual if you need .
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Good luck and please rate
Sep 24, 2009 | RCA TruFlat 27F520T 27" TV
Westinghouse 32" TV NO Singal rabbit ears
Buy a digital antena,or a roof antena set it up plug it in,the in hole said Input or Ant..Go to the menu select where said Cable or Air.Select Air for free Air Tv.Scan for channels.
Sep 12, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
May 24, 2009 | Philips 26PF5320 26 in. LCD Television
DWT1905 - No CATV/ANTENNA CHOICE
You will probably find your answer in the manual; the unit is built by Funai:
http://www.funai-corp.com/6pdf/om/DWT1905.pdf
Aug 16, 2008 | Durabrand DWT1905 TV
Cable setuo for model 27r410t
Get an antenna hooked up, even rabbit ears should pull in a few analog channels. Set top boxes will only output Ch 3 (switcheable to ch 4 on the back if needed) and cable may be dead or only give you scrambled CATV channels. You need to set your tuner to "antenna", not CATV, IRC,HRC, or ATSC (if you have a digital tuner) and do the setup again. You could have a bad tuner at worst, and all is not lost, just hook up a VCR via RCA cables and use the VCR tuner to change channels. Keep TV on Ch3.
Feb 12, 2008 | Televison & Video
NO CATV working on Curtis RT700
Yes if the unit is capable of picking up cable, there is a channel setup menu in the main menu. You half to switch it over to the cable mode. it should be in the owners manual. Good Luck
Jun 28, 2007 | Curtis RT700 7 in. Portable Television
Emerson EWC1902 19 in. TV/VCR Combo Logo
904 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
