Canon imageRUNNER 1019/1023 series copier makes loud clacking noise as it copies.
  • mortis Aug 18, 2008
    system error E 197
Como utilizo esta fotocopiadora con mi pc si no me trajo el cd de intalacion
Posted on Nov 01, 2008
Intrucciones de uso en español
Posted on Jul 09, 2008
Copier making loud noise
Remove the drum/toner unit and close the top,...does it still make the noise? If so, there is a paper jam in the fuser section (left side)
I also have a Canon PC900 series copier....mine does not have the automatic document feeder, however the machine is the same....If the noise persists, you will probably need to replace the Fixing (fuser) Unit drive gears (worst case senerio) perhaps you can locate the jam in the fuser and "carefully" remove without damaging the Fixing Belt....good luck
Jul 02, 2009 | Canon Office Equipment & Supplies
Canon imagerunner 1310 loud noise
Hello sir; I suggest reinstall drum unit again ,you will find out what's going on.
Apr 28, 2009 | Canon ImageRUNNER 1670F Copier
Canon ir c3200 copies are shake what i do
Is the copier making a load noise? You may have a broken driver gear in the fixing unit.
Apr 05, 2009 | Canon imageRUNNER C3200 Copier
Sharp AL1642 CS Copier Grinding noise and Paper Jams
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Nov 19, 2008 | Sharp AL-1642CS Copier
Canon PC920 paper feed "clacking" & not working.
check the tray and make sure the guides are set correctly, clacking sound is usually because the tray is set for Legal and has Letter, the paper is towards the bac of the tray and the pick up assembly is making the noise,
otherwise the tray is either not going up (broken gear, )
Aug 22, 2008 | Canon PC-920 Black and White Copier
"Clacking sound when receiving faxes"
a clacking noise is not good, what's the make and model of your machine.
Thank You,
Mikey
Apr 04, 2008 | Brother IntelliFAX 4100 Laser Fax
2,021 people viewed this question
jasbo
jasbo
