Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
DELONGHI 3500 THE INFUSER IS OUT OF THE MACHINE AND THE PART TO INSERT THE INFUSER IS LOWER THAT NORMAL CAN PUT THE INFUSER BACK IN IT WILL NOT FIT I TRY TO RESET THE MACHINE AND RAISE IT BACK UP BUT WILL NOT MOVE. I HAVE BEEN TOLD TO CHANGE THE PC BOARD AND TRY THAT TOO. I AM RUNNING OUT OF IDEA ON HOW TO PUT THIS INFUSER BACK IN THE MACHINE CAN YOU HELP. PLEASE RENE
Delonghi 3500 turns, runs diagnostics and then shuts off. Won't turn on unless you pull the switch. Any Ideas?
Posted on Mar 29, 2011
Delonghi magnifica has exclamation
Switch the machine off, AND pull the plug, wait 5 minutes (to be sure) and turn it on. Then turn it off again, now the infuser should return to it's normal position where you can take it out.
If the descale button is still flashing, try descaling again. Was the procedure interupted before? That would be a reason the light keeps flashing.
Bert
Nov 19, 2015 | DeLonghi Coffee Makers & Espresso Machines
When i turn on my delonghi magnifica pronto on its says insert brewing unit but its already in plus it makes a really loud noise when i turn it on
Sounds like the brewing unit, or infuser, has not been properly seated into its holder. Are you sure that the two red retainer fittings are in their snapped out positions? See page 16 of your owner's manual.
If the infuser has not been properly seated it could cause a loud noise when the servo drive tries to raise the unit into its brewing position.
Sep 04, 2014 | DeLonghi Coffee Makers & Espresso Machines
Delonghi magnifica rapid cappuccino model EAM 3400.S KEEPS SAYING INSERT THE INFUSER, I HAVE PUT THE INFUSER IN AND IT HAS CLICKED BUT IS STILLS SAYS INSERT THE INFUSER
try cleaning any old bean dust ect with vacuum ... refit or replace infuser lot better . if still no good you need someone to check pcb assy ... bsc appliances 07779933829 we cover repair service anywere via post.
Nov 28, 2010 | DeLonghi EAM3400 Espresso Machine
Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
May 24, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Insert infuser assembly alarm on De longhi coffeemachine
Did you try tightening the 2 hex screws behind the infuser?
Be gentle though. Mine felt tightend but thenIput just a bit more pessue on them and got an eigth to a quarter more turn out of them. Found this solution on this site
Jan 15, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Delonghi magnifica coffee machine...infuser jammed in machine. Needs to come out for cleaning. Can depress red buttons but it wont come out..looks a but squint
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Nov 02, 2009 | DeLonghi DCM485 Coffee Maker
Infuser will not come out, can anyone help?
the infuser is tilted and I cannot get it back to center
Jul 20, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Magnifica always asks "Insert Infuser Assembly"
DeLonghi "Insert infuser assembly" error
Easy Fix - Delonghi Coffee machines which have built-in coffee grinders often suffer from a problem that produces an error, "Insert infuser assembly" that appears at random times.
The problem is usually caused by distortion of infuser lifting mechanism limit switch mounting (Orange colored plastic)!
The mounting is very close to the water heater so with heat and pressure from the infuser lifting mechanism the mounting gets bent over time. The switch mounting (Orange colored plastic) gets permanently distorted so the striker arm on the lifting assembly only just presses the micro switch button causing the error message "Insert infuser assembly".
To easily fix the problem on ESAM 5500 machines and should work on other similar machines:-
    1.Unplug the machine and remove the rear cover screws and remove.
    2.Slide out the two side covers.
    3.Remove the grinder lever screw in the top cover coffee bean compartment.
    4.Carefully lift the top cover pushing it slightly back so it does not stick under the front cover (you may have to loosen the 4 front cover screws on the side).
    5.The limit switch is clearly visible on the top (see photos).
    6.Wedge some insulated material (wood, plastic etc, I used bamboo) between the heater assembly and the switch mounting so the switch is in a VERTICAL position. The thickness of the packing is around 3-4mm (see photo).
    7.Re-assemble the machine and enjoy your coffee. JTS
    Alwar, Rajasthan
    India
Apr 01, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
The machinge keeps asking to insert brewing unit but it seems to
The infuser does go in at a slight angle "11:45" ish. Be sure the tabs on the sides of the infuser "pop" back out when it's in place. Try unplugging the machine if all else fails and it will do a self diagnostic. You could also call Delonghi tech support.
Jan 02, 2009 | DeLonghi EAM3400 Espresso Machine
Magnifica gives Generic Alarm Message - Infuser stuck
My infuser was stuck in the down position, When I called customer support the told me some easy steps to fix this problem..try calling them
Nov 28, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
542 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
