Unable to get Lexmark 1180 to run on windows xp home premium!
Keeps asking for file pdflib.dll
Have I got the wrong driver?
No problems when running on windows me
Try going to dll-files.com and download the necessary file. Copy that file to C:\Windows\System. Hopefully this works for you. If not, you could also reinstall Windows which will reinstall the necessary files.
its not a problem. If you want to reset it try to go to properties->change and brows. Go to windows->system32 and click on rundll32. Anyway even keeping that setting won't do any damage ;). The selection will be made automatically when a dll tries to run.
Go to start : All Programs: Accessories: right click on Command Prompt, click run as administrator. click continue: you should see C:\Windows\system32> type there regsrv32 wmp.dll
It should look like this C:\Windows\system32>regsrv32 wmp.dll
(make sure to put the space in between 32 and wmp)
An info box will appear. Click Ok then restart.
That should fix it!
U can Find & Download This DLL File form Following Web Link......
http://www.dlldump.com/dllfiles/M/msls31.dll
After Download this file follow the blow steps-
1- Copy & Paste this File in "C:\windows\system32"
2- On Desktop Click on "Start" & Click on "Run"
3- When Run window appear, type the following command
regsvr32 msls31.dll
NOTE: Give a Space Between regsver32 & msls31.dll 4- After type the command hit ok, a popou window appear again hit ok
That Done Now Ur EZ Soft should Run Properly....
If after this any problem persist, send me the error (as given by window). I will happy to help U.
Tip:- U Use XP Home Edition, It is Good But I Suggest U that U should Use XP Professional SP2 Edition it is Better & Having more Softwere Competibility.
HERE IS THE SOLUTION : click on the link given below and find oc25.dll....if you are unable to find press keyboard key cntrl + f .A dialog box will appear now type oc25.dll and hit find key and you will find the oc25.dll .click on that file to download it to your computer.
http://www.dlldump.com/dll-files/O_2.html
Once you have downloaded the file you are looking for you still need to
make sure Windows or the program causing the error can find it. Follow
these steps:
1. If you are encountering an error with Windows... The
file you downloaded needs to be placed into the Windows System
directory. On most machines this is one of the following locations: C:\Windows\System (Windows 95/98/Me), C:\WINNT\System32 (Windows NT/2000), or C:\Windows\System32 (Windows XP).
If you are encountering an error with a particular program... The
file most likely needs to be in this program's directory. This
directory is where the program is installed (i.e. c:\Program
Files\ThisProgram).
If this step solves the problem, you do not need to complete step 2.
2.
You may to register this file with Windows. Click on the Start Menu and
then on 'Run'. If you are replacing a Windows system file, type the
following command: regsvr32 \windows\system\file.dll (Windows 95/98/ME), regsvr32 \WINNT\system32\file.dll (Windows NT/2000), or regsvr32 \windows\system32\file.dll (Windows XP).
For example, 'regsvr32 \windows\system\apphelp.dll'
If
you are replacing a file for another program, change the directory
where appropriate. For example, 'regsvr32 \program files\Norton\xyz.dll'
If the file is registered correctly, you will receive a positive confirmation message. ------------------------------------------- Please let me know your feed-back.
I found this possible solutions for your problem.
Most likely some software installation has messed with the file Scrrun.dll and
possibly other WSH files in folder windows\system32, or it's registration.
1)It may not be registered properly.
From Start/Run, type
regsvr32 %SystemRoot%\system32\scrrun.dll
You should now get this message box:
RegSvr32
DllRegisterServer in C:\Winnt\system32\scrrun.dll succeeded.
OK
2)If this doesn't solve your problem, download and install WSH 5.6 from here:
http://msdn.micr-
osoft.com/nhp/Default.asp?contentid=28001169
