Question about HP DeskJet 3325 InkJet Printer
Printer not printing!
Hi Tom
since changing the ink cartridge over i am unable to print anything off. Also the geen light keeps flashing.
can you help?
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!
so when you change the cratridge of your printer the cause the problem
try to remove and the catridge and put it back properly!!!
Posted on Sep 19, 2008
Left ligh keep flashing. after installing new ink.
  • Make sure cartridge is placed in properly,
  • Re seat the cartridge and check.
  • It should work
Please rate my response!!
Jan 29, 2010 | HP DeskJet 940c InkJet Printer
Canon S6300 not printing
I would recommend you to uninstall the printer and reinstall it back again....
Jan 17, 2008 | Canon BJC S6300 InkJet Printer
Teardrop light is flashing yellow. Green clock at left is lighted. Control panel says everything is ready but it won't print. There is no paoper jam.
This light that is showing the Print Cartridge Status. Here is what you can do:
If the light is on and not flashing: Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge. If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn off, then turn on the printer.
If the light is on and flashing: Verify that the correct print cartridges are installed.
Follow these steps:
1. Open the printer's top cover, remove the black or photo print cartridge, then close the cover.
2. Do one of the following:
  • If the light is flashing: Open the top cover, replace the print cartridge you removed, then remove the tri-color print cartridge. Go to step 3.
  • If the light is off: There is a problem with the print cartridge you removed. Go to step 3.
3. Manually clean the print cartridge.
After cleaning the print cartridge, reinsert it into the printer. If the print cartridge status light continues to flash, replace the print cartridge.if the light is on and not flashing. Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
Jan 07, 2010 | HP Hewlett Packard Deskjet 5650 InkJet...
Blinking red light, unable to turn off or print
From the looks of your printer. I'd say that one of your ink has a problem. The part where you put the cartridge in, is where your problem lies. YOu'll prob need to get it checked out by an HP dealer.
try changing the ink cartridge and see if that helps.
Aug 12, 2009 | HP Photosmart D5160 InkJet Printer
Red & Green Lights keep flashing on Epson Stylus Photo1280
I had the same problem. You need to reset the waste ink counter:
1. Turn printer off, unplug power cord. Disconnect computor interface cable (back of the printer).
2. After one minute, reattach power cord, but not the computor interface cable.
3 Hold down the LOAD/EJECT and CLEANING buttons simultaneously (cleaning button has ink drop on it) .
4 Turn printer on. Release all buttons as soon as the paper out light flashes.
5 Quickly press the cleaning button, and hold for 10 sec while paper out light flashes.
6 Release the button and the printer will initialize.
7. Once the initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on and try to print your document.
This process worked for me. Good luck!
Feb 01, 2009 | Epson Stylus Photo 1280 InkJet Printer
Put in new ink cartridge -- won't print
Try lifting up the cover. If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing. If the problem is not related
to low ink, the light continues to flash after the cover is opened. It might be that the new cartridge is defective. Check the connections and see if there isn't anything keeping it from making contact.
Jan 26, 2009 | HP DeskJet 920c InkJet Printer
Red light ink cartridge keeps on blinking
what does it say next to the blinking light for example check paper, check ink cartridge, etc.?
tom
Dec 20, 2008 | HP PSC 1350 All-In-One Thermal Printer
Not able to print
Faulty cartridge. Yes, it happens. Specially if it is not an HP replacement. Try inserting the old one and see if it stops the light. If it works, get a refund on your new cartridge.
By the way, did you remove the tape from the contacts before installing?
Jun 03, 2008 | HP DeskJet 3325 InkJet Printer
Orange flashing light on printer
No the ink is not to low you could try removing the ink cartridges and using a soft cloth wipe clean the little gold contacts on the cartridge and also the printer. Is the ink cartridge a original one if not even though the HP software states that there is 20% in there the likely thing is that the cartridge is empty replace and this should be OK.
I hope the first suggestion works for you as will not cost any money.
Thanks J
Jan 12, 2008 | HP DeskJet 930c InkJet Printer
C120 Installation Problem
call the manufacturer immediately for ink replacement.
Jan 07, 2008 | Epson Stylus C120 Color Printer InkJet
HP DeskJet 3325 InkJet Printer Logo
46 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
