Question about Whirlpool Dryers
Heating element whirlpool dryer
Where is it located, how do i replace it
  • 868 Answers
On the burner youll see the igniter it has 2wires plugged into it. heating element whirlpool dryer - 91a76df.jpg
Posted on Jun 03, 2008
MY DRYER WON'T HEAT.
This is usually caused by a blown thermal cut-off which blows and cuts power to the heating element due to the failure of the high limit-thermostat to cycle off and regulate the heating element temperature. Check the dryer for clogged lint screen and/or restricted vent system then replace both thermostats when either of them has failed. Both are located on the blower housing.
Click on the links below for the detailed troubleshooting of this dryer problem. Just follow the instructions that are applicable to your dryer since you did not specify the dryer's exact model number.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Bottom Panel) Running But Not Heating
Jun 17, 2011 | Whirlpool Dryers
I HAVE A RED4340SQ1 ELECTRIC DRYER WHERE IS THE HEATING ELEMENT LOCATED
The heating element is located at the rear of the dryer behind the rear access panel. Disconnect power then remove the screws attaching the rear access panel to the cabinet and remove the panel.
Your dryer seems not heating but it doesn't mean the heating element is busted. The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed procedures.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 27, 2011 | Whirlpool LER4634J Electric Dryer
The dryer runs but there is no heat coming out of it
lllThis is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
Jan 18, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
Not heating
The Most common problem is a bad thermal fuse.
1 the thermal fuses are located in the cabinet of the dryer under the drum
they can also be located on the front of the blower wheel housing. on the back wall of the dryer or along the heating element can.
2. some kenmore, whirlpool machines have these fuses located in the rear of the machine.especially when the lint filter is located in the top of the dryer.
3. the heating element can also be bad.
4. if you have an ohm meter you can check the continuity of the thermal fuses,as well as the heating element.if there is no continuity on any of the above mentioned parts. Replace the faulty parts.
Also check my tip on thermal fuse locations
Jan 09, 2011 | Whirlpool Dryers
My dryer will not produce any heat ? it is only air drying. Is there an element I need to replace or a fuse ?
Jan 08, 2011 | Whirlpool LER4634J Electric Dryer
How do you replace the heat element on a whirlpool LER8648 dryer?
Before replacing the heating element, check first the continuity of the thermal cut-off and the high-limit thermostat located on the heater box, the resistance of the heating element, and the continuity cycling thermostat located on the blower housing. Replace the heating element only when it reads open. Replace both the thermal cut-off and the high-limit thermostat should any one of them is found open. The cycling thermostat must have continuity between its thicker terminals; otherwise, replace it.
All of the above components are accessible through the rear of the dryer. Remove the rear panel by removing the screws securing i to the dryer cabinet. Replace the heating element by removing the screws attaching its housing to the heater box then securing the new heating element housing in place.
May 28, 2010 | Whirlpool Dryers
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Dryers Logo
227 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
