Question about HP DeskJet 3325 InkJet Printer
Not able to print
I am unable to print anything off. The greenlight keeps flashing!. Was all working before i changed the ink cartridge.
help
    Scholar:
  • 136 Answers
Faulty cartridge. Yes, it happens. Specially if it is not an HP replacement. Try inserting the old one and see if it stops the light. If it works, get a refund on your new cartridge.
By the way, did you remove the tape from the contacts before installing?
Posted on Oct 11, 2008
I replaced the black ink and it keeps saying replace ink cartridge. I actually went ahead and changed the color as well even though it did not ask and it keeps saying replace cartridge. HELP! I am a...
Did you replace the ink cartridge with a new one, or did you refill an old one.
Some printers have a memory and can tell which ink cartridge is in them. This prevents them from easily being fooled into printing with refilled cartridges.
Another option is that you changed the ink cartridge without following the specific guidelines for replacement e.g. To replace the ink cartridge, select replace ink cartridge from the main menu, then open the printer panel when the light flashes X number of times.
You might also try unplugging the printer for a couple of minutes the reset it.
Oct 15, 2009 | Office Equipment & Supplies
Blinking red light, unable to turn off or print
From the looks of your printer. I'd say that one of your ink has a problem. The part where you put the cartridge in, is where your problem lies. YOu'll prob need to get it checked out by an HP dealer.
try changing the ink cartridge and see if that helps.
Aug 12, 2009 | HP Photosmart D5160 InkJet Printer
Put in new ink cartridge -- won't print
Try lifting up the cover. If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing. If the problem is not related
to low ink, the light continues to flash after the cover is opened. It might be that the new cartridge is defective. Check the connections and see if there isn't anything keeping it from making contact.
Jan 26, 2009 | HP DeskJet 920c InkJet Printer
Ink light keeps flashing -
Have you made sure that you've taken the plastic strip off of the ink cartridge? I had this problem once and I then realised that i had forgotten to remove the strip covering the ink.
Also, have you installed a colour cartridge? I have the same printer and it wont print unless you have both ink cartridges inserted and in good condition. (If you don't want to fork out for HP Original, I find that the Tesco Remanufactured versions work fine)
Hope this helps.
Joe
Jan 01, 2009 | HP DeskJet 930c InkJet Printer
Epson stylus cx4400 printer
This for the CX5400 which is similar with its menu system:
Using the Control Panel Follow the steps below to replace an ink cartridge.
r_1.gif Make sure this product is on and the On light is not flashing.
When the ink is low:
Press one of the Menu buttons until Change Cartridge appears on the LCD panel, and then press the fontx1.gif Color Copy button. The ink cartridges move to the replacement position. r_3.gif Make sure that the document cover is closed, and then raise the scanner unit.
a8101037.gif r_space.gif r_caut.gif Caution: r_space.gif r_space.gif
  • Do not raise the scanner unit with the document cover opened.
  • Do not move the print head by hand. Doing so may damage this product.
  • Do not start replacing the ink cartridge before the print head stops.
r_4.gif For best results, shake a new ink cartridge four or five times, then remove it from its the package.
a8102006.gif r_5.gif Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of this product and dispose of it properly. Do not take the used cartridge apart or try to refill it.
a8101049.gif r_space.gif r_warn.gif Warning: r_space.gif r_space.gif Be careful when you are handling used ink cartridges, as there may be some ink around the ink supply port. If ink gets on your skin, wash the area thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. If discomfort or vision problems remain after thorough flushing, see a doctor immediately.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif Be sure to always install an ink cartridge into this product immediately following the removal of an old ink cartridge. If the ink cartridge is not installed promptly, the print head may dry out rendering it unable to print.
r_6.gif Place the ink cartridge vertically into the cartridge holder. Push the ink cartridge down until it clicks into place.
a8101051.gif If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7. r_7.gif Lower the scanner unit.
a8101039.gif The print head moves and ink charging begins. The On light flashes while ink charging is in progress. When the On light stops flashing, ink charging is completed.
Jun 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Printer not printing!
hi!!!!
so when you change the cratridge of your printer the cause the problem
try to remove and the catridge and put it back properly!!!
Jun 03, 2008 | HP DeskJet 3325 InkJet Printer
Printer is on but cannot print
if your power light is off and the paper and ink lights are flashing try this.
1. remove all the paper,
2. open the cover and check for paper jam
3. make sure the ink cartridge lid is securley in place by opening and re closing the ink cartridge lid
reclose the lid, disconnect the power supply and hold the power button for 30 seconds. reinstall the power plug and turn the printer back on.
hope this helps
May 12, 2008 | Epson Stylus® Photo R2400 InkJet Printer
Orange flashing light on printer
No the ink is not to low you could try removing the ink cartridges and using a soft cloth wipe clean the little gold contacts on the cartridge and also the printer. Is the ink cartridge a original one if not even though the HP software states that there is 20% in there the likely thing is that the cartridge is empty replace and this should be OK.
I hope the first suggestion works for you as will not cost any money.
Thanks J
Jan 12, 2008 | HP DeskJet 930c InkJet Printer
C120 Installation Problem
call the manufacturer immediately for ink replacement.
Jan 07, 2008 | Epson Stylus C120 Color Printer InkJet
I keep getting an error message- unable to clean....I just bought and installed new ink cartridges, and the machine is still having trouble - I cannot print at all now. There seems to be no way to clear...
The waistinktank has to be replaced. DO NOT only reset the code but change the waistinktank! Otherwise ink will flow into the machine and will cause serious damages!!!!!!!! See link how to do that: http://www.fixya.com/support/t202485-cleaning
Oct 05, 2007 | Brother MFC 420CN All-In-One InkJet...
HP DeskJet 3325 InkJet Printer Logo
53 people viewed this question
Ben Johnson
