Question about OfficeMax 0M96431 Shredder
Office Max Shredder #OM96146
Paper is constantly getting jammed. The paper is tightly wound around the teeth and cannot clean it. What can we do?
  • 2 more comments
  • crazystupid Oct 03, 2008
    it runs a while and stop. The power is on, but the stupid cuting does not run. what is the solution
  • Anonymous Oct 29, 2008
    the teeth have become warped due to normal usuage. As a result paper is becoming stuck to the teeth and increasing in diameter. I have tried using small knives and tools to loosen the paper. It is very time consuming and then becomes stuck once using the product again.
  • atenor Oct 30, 2008
    Appears ready to go but will only start shredding for a second and then a relay clicks. I think it has something to do with the paper sensor
  • kahuna44 Apr 11, 2009
    I have the same problem - after limited use of the OM96146 the shredding wheels became clogged/jammed and then bent in/spread out so that the shredder does not perform its intended function. What a piece of junk.
Don't open it, check on product warranty policy and take it back or send it in.
Posted on Jun 22, 2008
My ativa 12 x-cut paper shredder runs for 1/2 sheet then stops. how would you identify problem and fix it
The sheet detector may be malfunctioning. Your shredder may have to be cleaned to restore proper operation. Mine gets clogged periodically and has to have the bin removed so the entire shredder can be turned upside down to perform dental hygiene on the teeth. Paper shreds even get jammed in the spaces between the teeth. Flossing doesn't help!
Mar 07, 2015 | Shredder Office Equipment & Supplies
Ativa shredder manual
Are the shredder blades going around? most shredders have guides that guide the paper between to shredder gears or teeth. these guides are usually made of plastic and breake. First step is to see if the shredder gears or teeth ar going around.....
Sep 23, 2013 | Office Equipment & Supplies
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
Paper has wrapped around the cutting blades and is packed in tight. How do I clean this?
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
    • 3 Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Office Equipment & Supplies
Thanks! I have a 7x Crosscut Paper Shredder, Model # PCUA:29053U. The teeth are jammed due to I believe a build up of paper. I have run it on reverse & tried to pick out the paper. The motor runs but...
If the motor runs but the cutting teeth dont turn then you have stripped or broken a gear in the drive train. You can get replacement parts from Royal at 1-800-524-0799.
Oct 19, 2010 | Royal Office Equipment & Supplies
Teeth are bent and paper/material from credit card is jammed
One teeth are bent in this and other similar lower end units, they can't be fixed. Return it to the place you purchased it from and see if they'll be gracious enough to replace it. But these machines are not intended to handle a lot of the heavy guage stuff people put in them. The cost of a replacement cutter unit, if one can be located, would be more expensive than buying a new one.
Aug 21, 2009 | Office Depot Ativa DQ60M Shredder
Shredder rollers do not turn; motor works good; all gears go arou
Will it work in reverse? Can you see the gears are they all moving? Is there a set pin?
Apr 03, 2017 | Adler Royal HT500X Shredder
My mailmate shredder from Staples has jammed and I can't figure out how to unjam it.
unfortunately you will have to do it by hand!!!!!!!!
unplug, get a flat head screwdriver, take off top and turn upside down. you will see a lot of sredded paper where the teeth are, you need to clear all of that.
it may also be that you have a stale or something of that nature blocking the teeth.
Also do a reverse, I did one over the weekend and had to do it several times while cleaning it out, very messy so make sure you do it somewhere that you can easily clean up, also don't forget you are supposed to use a special lube paper once in a while. (Office Depot,/Max/Staples
Aug 24, 2008 | Office Equipment & Supplies
Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
Jun 03, 2008 | Office Equipment & Supplies
OfficeMax 0M96431 Shredder Logo
865 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Randy Schumann
Randy Schumann
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
