-   Our beverage center is only a few months old, and both sides are stuck at "HI" and "HI", and it cooked all of our wine, all 24 bottles are now vinegar! Does anyone know how to fix this?-   Guest
Jan 10, 2009
-   The temperatures will no longer reset and remain in the mid 70s, above room temperature, slowly cooking our wine... the motor, which was quite loud when the Danby was working, has gone silent. Warranty long since expired.
-   my cooler is leaking water from condensation. how can I fix this? I can't seem to get the temp's to reset they stay cold. i've tried reseting both top and bottom temps and the computer inside won't set. my coolers is only a year old. -   juicygurl_1
Nov 30, 2008
-   Our cooler is only about a year old and was only used for about 4 months before being stored. Now we've moved and plugged it in and it is getting HOTTER instead of colder. -   rsanders3645
Aug 10, 2008
-   Been trying this for weeks and no luck. It is stuck at 65 and 66 degrees, similar I guess to the room temp here in the basement. Tired to reset many ways, none worked. Needs to go back.
-   madryga
This happened to me, I found that the cooler would not go below 70 degrees because the cooler had lost its coolant or wouldn't work. I do not know, but as it was under warranty, an appliance repairman came and said that it was worth fixing, so it was replaced with in a week. Normally you would just hole the button in until the desired temperature is selected. Once released the cooler would attempt to set this temperature. If it is not, then I suspect it too is broken. Good luck.
Upper Fan replacement - I have removed all screws holding the back plate in place. I cannot remove...
(More)
Upper Fan replacement - I have removed all screws holding the back plate in place. I cannot remove it to replace the fan since the large section holding the electronics is in the way. Am I missing something in order to get access to the upper fan????
