Question about Brother GX-6750 Typewriter
Correctio tape plate
I cant push down the corrective plate down
    Sergeant:
  • 329 Answers
Under this plate there is a small spring loaded pin the has to go in a groove in a ribbon lift wheel, Usually there is a hold throught this plate where you can see this. The pin has to be pulled back and let the spring tension push the pin in the groove. Hope this helps...
Posted on Jun 24, 2008
Tape door won't close because tape tray won't go down
If the battery is charged, and the power is on, it may be jammed and in need of cleaning. If that is all normal the motor for the tape door may be damaged or has died. Insure tape position is correct and only push where marked.
Oct 03, 2015 | Panasonic AG-DVX100B DV Digital Camcorder
How to replace the throat plate spring
This can be tricky. At a 45 degree angle push the top spring under the holding area of the machine. Hold this spring firm and push down on the second spring. Rotate the throat plate simultaneously until the plate is in its correct position.
Aug 13, 2015 | Sewing Machines
How to attach loose scanner glass
The glass plate in scanners is almost always held in by some kind of 2 sided adhesive tape AND plastic clips. Th adhesive probably failed, but the glass plate is probably at an angle and not resting on the plastic clips correctly. These act as a failsafe in this very situation, so the glass plate doesn't break or damage the scanner guts.
Anyway, if you want a permanent repair, this is the tape you should use: Amazon com 3M Scotch Heavy Duty Mounting Tape Clear 4010 Double Sided...
It will definitely support the weight of the glass and then some. Be careful with this stuff, it will remove paint (or worse) from drywall. You should only need 4 strips, one for each edge of the glass. Apply it firmly to the glass, then stick the glass onto the plastic bracket.
Apr 13, 2014 | Epson Perfection 1240U Flatbed Scanner
Typewriter does not correct
There is a cam cluster under the ribbon plate that has to move over when you hit the correction key this lifts the correction tape, make sure the lift is not working and that the correction tape is old, and just does not lift off, have seen that...
Mar 21, 2014 | Brother ML-100 Typewriter
Nikki carburetor Throttle plate sticks
Try installing the throttle plate in the opposite direction, upside down.
Jun 22, 2013 | Briggs & Stratton Garden
How do you remove driver door panel ? the electric window broke, you can hear something rattling inside
Motor & Regulator
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Lower the window to the down position.
  3. Remove the door trim panel.
  4. Remove the door water deflector.
  5. Remove the window-to-regulator bolts.
  6. Push the window to its full up position and tape in place.
  7. Remove the nuts from the regulator cover plate.
  8. Remove the regulator drive cable from the rear of the cover plate and remove the cover plate from the door.
  9. Disconnect the electric connector from the motor.
  10. Remove the regulator bolts (1, 2, 3).
  11. Pivot the regulator (right door clockwise, left door counterclockwise) and slide the assembly out of the door.
  12. Remove the motor/regulator from the vehicle.
    Remove the regulator bolts (1, 2, 3) and remove the motor/regulator from the vehicle
To install:
  1. Partially install the three bolts (2) to hang the regulator in the door.
  2. Position the regulator in the door and hang it in place.
    NOTE
    Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  3. Install the regulator bolts and tighten to 89 inch lbs. (10 Nm).
  4. Install the electrical connector to the motor.
  5. Slide the window down to join the regulator.
  6. Install the window to the regulator bolts and tighten to 89 inch lbs. (10 Nm).
  7. Install the regulator cover plate nuts and tighten to 89 inch lbs. (10 Nm).
  8. Install the regulator drive cable (1) to the rear of the cover plate.
    NOTE
    The regulator drive cable goes into position (2) for the coupe and position (3) for the sedan.
  9. Check the operation of the window.
  10. Install the water deflector.
  11. Install the door trim panel.
hope this helps you
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 29; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Jan 15, 2011 | 2003 Pontiac Grand Am
The bottom tray in my Kodak esp7 is stuck in the open position and will not shut
I'm assuming you are talking about the paper tray. Paper trays usually have a metal lift plate in them. The plate is spring loaded. When the tray opens, the spring is actuated and it lifts the paper upward. When the drawer is pushed back in, there is a guide inside the printer that pushes the plate down. Sometimes that plate doesn't hit the guide correctly. Look at where the tray is sitting inside the guide while it's going into place. You should see where the plate should be. There will likely be a path on either side of the printer on the inside that guides the plate downward. Try to push it back into place or take the tray out and guide it back by hand. You'll see that there might be something blocking it as it goes in. Sometimes when you guide it in manually, the tray will correct itself.
Jan 14, 2011 | Office Equipment & Supplies
I have TEAC A 4010. Motors are running, belts are ok, but tape does not turn. When I push on the capstan the tape wants to turn, but stops.
Ensure the rubber pinch roller presses the tape against the capstan drive shaft....ensure the capstan drive motor is turning..and the belt to the flywheel is snug, and not slipping. the tape transport engage relay might be stuck...a relay maybe corroded ...may need cleaning. Without seeing it cant say clearly what may be the problem. also ensure the tape tension/shut-off arm is under tension by tape that is correctly installed.
Oct 27, 2009 | Audio Players & Recorders
The tape carrage wont load the tapes but it will go into the load position without.
I have a sony cam myself. If the cam is empty, you open the outer door(swings out), and the load/unload mechanism rises up and pops open allowing tape insertion. When a cassette is placed into the mechanism, you press where it says "push" and then the drive pulls the tape down and into the unit. Then the outer door is closed and you're ready to tape. IF YOU PUSH DOWN ON THE TAPE WHILE IT'S BEING PULLED INTO THE UNIT IT WILL STRIP GEARS INSIDE. The gears are made of nylon to prevent serious damage to motors and other circuitry. This transport setup cannot be forced at all. If any type of mis-alignment occurs, the mechanism is supposed to stop and back up--allowing the problem to be corrected. If it is damaged, the cam must be repaired. There is critical timing involved in replacing the tape carriage.---Rick
Sep 10, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
The correctional tape isn't popping up to white-out the errors. Instead the actual ink is typing where it should be correcting making the letters bold. I tried tightening the correctional ribbon and the...
Hello. I had a similar problem, and Upstatoes helped me. Mine started with striker stuck forward, and then went to working for a few days, but sticking forward again And it was caused by the spring not being in the right place. But the correction tape housing is pushed up and pulled down by the white, adjustable piece on the right side, that has the screw holding it into the adjustment place. If you take off the ink ribbon, push the carriage to middle, and turn on the typewriter, there will be a switch at the top left of the keyboard, on the underside, you will need to flick with your finger, one time, as the carriage moves to the left. This is the reference switch, and you will be tricking the typewriter into thinking it is now in the left side start position. After this, you can see the white adjuster piece on the right side of the carriage, and, as you type a letter, also see if it is holding down the correction tape housing. Then when you hit the erase key, see if the cam on the inside (looking through the small holes in the correction tape housing) turns and pushes up this housing? It may be the tab in the white adjuster is not inside the grove of this cam. Either way, at that point, you may be able to see if something else is not as it should be? My problem was the long side of the spring was not underneth the white adjuster. (I had been putting it under the housing, and it was not helping ot push everything up like it should be.) Aparently this cam with the white adjuster tab in the groove holds everything down, easily, as you type, but has to have the spring help to push up when you use the earse key.
Aug 15, 2008 | Brother ML-100 Typewriter
Brother GX-6750 Typewriter Logo
57 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
