Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Getting the pump to work
Wow great advice. Thanks for letting me know how to open up the Powersteamer 1695C. Most of the screws take a bit of searching but I never would have thought of peeking down the ends of the latch clips. What I did to get the pump going: I pulled the tiny motor away from the plastic pump and noticed it hummed but the shaft would not spin. It was siezed with a some corrosion and junk so I took a pair of pliers and rotated the shaft on the motor a few times to work it loose, and now it works perfectly. I added a drop of fine oil to the bushings on the ends of the shaft as well.
  • 1,673 Answers
Glad you got it going, you might want to run a mix of vinegar and water to clean it all out.(not on the carpet tho)
Posted on Jun 03, 2008
How to replace belt
This link: should supply all you need.
If you need further assistance, let me know.
Sep 13, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell powersteamer
BISSELL User's Guides can be downloaded at
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Jul 09, 2010 | Bissell 8806 Powersteamer Upright Vacuum
Loss of suction
DYSON DC08 ROOTCYCLONE Loss of suction problem.
I had this exact problem and solved it.
No offense to Dyson Customer Service, but that advice isn't nearly enough to explain how to clean the cyclone. I used to work in Customer Service for an electronics company and I never let anyone down because of clear and precise instructions.
So, here is my advice:
Remember properly where all the screws go and how the bits fit together. It's important so that there is no loss of suction due to improper replacement of parts.
Step 1
Remove the canister from the vacuum cleaner and take off the clear bottom bit - the container for dirt. Clean that out well, you can use water but MAKE SURE IT DRIES COMPLETELY.
Step 2
Pop off the conical bit at the bottom of the cyclone. It isn't held by any screws, just nudge it out of place.
Step 3
You will see three holes amongst the vacuum entry holes. These three holes have screws in them. Unscrew those.
The type of screws used are star-like, but I used a small flat-head screwdriver. Make sure the edges of the flat-head fit perfectly into the edges of the slot on the screw. This prevents grinding and damaging the screw.
Step 4
Turn the canister over, the grey handle conceals three screws. Two on top and one beneath the bottom of the handle at it's base. When you remove the two screws that are visible, you can gently pop off the handle from the canister. First pull the handle up slightly, then the hook unlocks at the base, then push the handle away from the air inlet hole.
Step 5
Turn the canister over again. The bit where you removed three screws should come off easily. Beneath that, you will see two more screws, holding the top bits together. Remove those screws.
Then, all of the cyclone is loose and you can clean each bit separately. Again, you can use water, but let it dry very well.
Step 6
Put it all back together.
Apr 13, 2010 | Dyson DC08 Cylinder Bagless Canister...
How to open up a Bissell Powersteamer 1695
About the only thing you might try is putting a mix of vinegar and water and see if it will open things up. Your model, Bissell has obsoleted all parts, so the pump is not available anymore. But there are 2 screws, take off the 2 latches, at the end is a hole to take out a screw.
May 30, 2008 | Vacuums
Belt broke
There should be an access panel on the top side of the cleaner. Pry this open with a screw driver and this should get you access to the area where the belt can be changed.
Apr 11, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell Big Green Machine Model 1672 will not pump cleaning liquid
have a Bissell Big Green 1672, the older canister model. Went crazy trying to figure out how to get to the pump. Finally figured it out. The top green "shell" covers the motor & pump and is separate from the "grey" plastic housing. Using a screw driver, insert it between the small gap between the top "shell" and the housing. If you look at it with it laying down on the top, you will see the small 1/4" gap. Gently pry in between the two and work your way around. It will start to lift up and then you can easily work your way around and it will pop off exposing the motor and pump. Note that the wires to the on/off & pump switches will sill be attached to the top shell. If you take them off note where they came from and make sure they are all on when you put the top back on. I have had my Green Machine for years, what a work horse! To bad they don't make them anymore, the new ones that replaced them just don't have the same durability and power as the older Green Machines.
Dec 19, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
47 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
