Question about Intel Desktop Board D850GB Motherboard
D850gb wont power up
Hi got power to the board.i think the problem is to do with the jumpers
  • 99 Answers
Posted on Jun 03, 2008
  • Larry Miller Jun 03, 2008
    should have added, ...for this motherboard
Stepmill 7000pt is free spinning and has no resistance.
How to Test the Relay Board on Stairmaster 7000PT Stepmill How to Test Relay Board of a Stairmaster Stepmill 7000PT Disconnect power from the machine.
Disconnect the main cable from the relay board J1 terminal. Main cable should remain disconnected for the duration of the relay board tests.
With the Power ON, place a jumper wire across the GND/BLK and RLY/RED test points. (Ensure jumper wire only makes contact with the designated test points.)
  • Verify that the Relay LED is lit. Remove jumper wire.
With the Power ON, place jumper wire across the +/WHT and FLD/BRN test points. (Ensure jumper wire only makes contact with the designated test points.)
  • Verify that the Field LED is lit. Remove jumper wire.
With the Power ON, place jumper wire across the +/WHT and with the other end touch the ALT/C, FLD/NC, and RES/NO.
  • Verify that the Field LED lights.
If any of these jumps fail, replace the relay board and or power supply. Stairmaster Stepmill 7000PT Electronic Testing of Relay Board
The second link will take you to the service manual. Starting on page 13, you will find some more valuable information on the relay board. Last link will take you to a video on how to test the alternator
Video about Performing Jumper Test on Stairmaster Alternator
Mar 12, 2013 | Stairmaster 7000PT Nautilus Stepmill
Tip
How to Test the Relay Board on Stairmaster SM916 Stepmill
How to Test the Relay Board on a Stairmaster SM916 Stepmill Disconnect power from the machine.
Stairmaster SM916 Stepmill Relay Board Testing
on Feb 25, 2015 | Stairmaster SM 916 StepMill
HP G61 no power
open *********** board battery some time or " mother board battery
inside 3pin jumper switch. open this jumper middle pin to other pin connect some time 1 minute & jumper set previous position.
or" see mother board battery
inside reset switch
May 28, 2012 | HEWLETT-PACKARD G61-306NR Notebook
Ddr jumper settings M925g 9.1b?
Hi Ronald.
Not completely sure but I think this is the manual for your motherboard.
You can download it here
Also not sure if it's complete, it seems to stop short, but that may be just me. It should open with Adobe Reader.
Jan 31, 2012 | Computers & Internet
Hi, my mother board is P5KPL-AM/PS,but can't detect my DVD-ROM, although i connect properly..i think,maybe is in my bios, can u help me about that plss.. more power
if your dvd rom by sata , from bios find "" load default setting"" then F10 (save and exit).
If it is IDE (with lenght cable), from behind of dvd-rom there is jumper, put it on slave. and turn on pc.
Jun 11, 2011 | Computers & Internet
I recently removed the cmos jumper from my board and now it cant
HI,
I'm not sure what your problem is, but put the jumper back on the board, and reboot it.
Mark
Dec 19, 2009 | Mercury P4VM800M7 Motherboard
Turn off power and reinstall the jumper in normal mode position
Try to clean the pins on the board, check the connection inside th jumper. (with multimeter or else). Try to clear the bios .
Feb 27, 2009 | Intel D945GCL Motherboard
Cmos clock will not set !
Is the cmos clear jumper in the wrong position? if it is it will drain the battery and mess up the clock, You may have to flash the eeprom with a newer version BIOS obtainable from the manufacturer, check their website on this to see if it is a known issue ( I have seen this on multiple other manufacturers main boards). If this isnt it it is possible you have a bad clock chip
Dec 31, 2008 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Am2 sli fault
does ur monitor light blinks if the monitor light blinks remove ur memory card and cleant the dust on the card and insert the memory card i think it will work
Nov 26, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Power on password
E may, vao day coi co con nho nay ngon lam http://nhatquanglan1.0catch.com
Oct 20, 2007 | HP Compaq nx6310 Notebook
Intel Desktop Board D850GB Motherboard Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
