Back to:
Tags:
Nikon Coolpix 5600 Digital Camera
Help I dont know what is wrong with camera!
posted by Crumbkitty on Jun 03, 2008
Every picture looks like this. I have checked settings but this is what I end up with. Do I need to buy a new camera?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 25, 2008
Not Rated (0)
Richie_asg1
Rank:Guru Guru
Rating: 86%, 181 votes
The exposure time is clearly too slow on this. Thank's for posting the pic.
If there is a sports setting, try it on this for low-light levels.
If all your daylight photo's are doing this, check the exposure settings.
If you cannot reset the exposure manually to restore this, then remove battery and memory card, leave for around 5 minutes, then load up again.
Check the exposure setting before using, and check the results.
If this does not correct it, try downloading a new driver for it Here
If the problem persists, it could be the metering device within the camera itself.
If under warranty, return the unit according to the warranty information, or get estimates for repair.
(If this cures the problem, please rate as Fixya so others may benefit from the advice. Thank you. )
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Help I dont know what is wrong with camera!:
I don't want to Accept this solution
Can you Help with these Digital Cameras problems?
when I power it on, it just freezes on the screen saver. I...
Similar problem as described by others. Pictures are...
My camera got wet, now the LCD screen on the back of the...
i Cant get my pictures to download onto my computer
When I turn on the camera, a red clock flashes on the...
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
