Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Color and curve issues
The colors will not align and the picture has an unnatural circular curve to it
  • teklady Jun 08, 2008
    same problem intermittent. Now just the green light turns on. Have tried multiple inputs. No picture. hi voltage looks good as far as we can test ourselfs. Color would come and go very intermittent, convergence was allways bad. Now no tv just green light. Help.
    Teklady@tampabay.rr.com
  • Philips Master
  • 3,459 Answers
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.  To help others like me I documented the fix and created a step by quide and repair kit to fix the problem. You can find it here. http://www.magnavoxhelp.com
Posted on Jun 20, 2008
    Scholar:
  • 131 Answers
  • I suspect you have a bad convergece problem. Requires replacing ic stks cost for servicer to due is 250.00 .If you
  • could solder and are good at repairing you could do this.
thanks doctor video
Posted on Jun 03, 2008
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Yellow Tint over picture...
well..it's simple really...yellow is from a degrading video unit and system board..so, you'll find that it's high time for a major service situation.
May 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Picture seems to be offline( curved down) also everything seems doubled and you can see the red, yellow and blue colors of the lenses on the screen
Tv have a problems known as a convergence problems it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the board that call the convergence board it is dead.This convergence board require service must be replacing parts 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems mis alignment.The tvs shops,will cost u like around $300-350 for parts and labors.
May 28, 2011 | Samsung HCM4215W 42" Rear Projection...
Picture is greenish / purplish and curved lines at top & bottom of screen. definitely not an input issue, distortion is the same on all inputs and even on the menu/settings...
Very common problem throught out ur DLP tv live,will happen again again many times for the tv life times.Ur tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 05, 2011 | Sony KP-65WV700 65" Rear Projection HDTV
Colors seperating and out ends of screen curved
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors pictures shadows or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 27, 2010 | Mitsubishi WS-55809 55" Rear Projection...
The picture looks more like weather radar than people.
exactly wuts happenin 2 me plus now it jus shuts off and shows vertical color bars for like 8 hours wtf let me know if u cme up wit a solution
Jul 15, 2009 | Protron PLTV-32 Television
Mitsubishi 1080 hd series 65" Curved picture
The problem is the convergence circuit.
Mitsubishi used two different types of convergence IC's in this series. The first is a pair of STK-392-570, the second is a single STK393-110. The only way to fix the problem is to replace the appropriate IC'S. In some cases the problem may appear to be intermitent or loose solder connections. Save yourself the anguish and replace the IC'S.
Getting the PowerSupply/ Convergence board
out to do this is tricky and I recommend a professional to do it. Hidden screws on the front of the heat-sink make it difficult to take out and you can break the board easily trying to force it.
Jun 17, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Sounds like the deguassing cicuit has failed . This aligns the purity of your colors .Most of the time it is a simple loose connection on the themistor or the degaussing input cord to the board . Or the thermistor is bad . The tv was not dropped ? If it was this could have loosened the shadow mask in the picture , then the only way to repair is the replace the picture tube . Good luck
Mar 04, 2008 | Panasonic CT-36D32 36" TV
Convergence issue resolved but concave picture remains
Set will need new convergence IC's.Requires chassis pull===technical & mechanical skill mandatory.After repair,re-aligment necessary.
Sep 26, 2007 | Philips 55PW9363 55" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
