Question about Philips 50P8341 50" Rear Projection Television
Seomthing you wrote before
Hello... I'm hoping to get some more information about something you posted. I'm a troubleshooting trainer for in a contact center in Florida. I'm hoping to get some help with a television that we are havinf issues with. Here's what you wrote:
The most common problem for this complaint is contaminated coolant for the picture tubes. If you look directly into the three picture tubes you will probably see a haze in the blue one. This is fairly common but requires a knowledgeable service man to take care of.
In reference to the technician...are you suggesting that the picture tube needs to be replaced or is there something else that can be done in order to get this issue taken care of..I'm learning by experience in my new postion, so any help would really be appreciated.
  • Philips Master
  • 3,459 Answers
You just need to drain and replace the fluid in the tubes. Its not easy but it can be done by a DIY if they have a service manual.
Check www.magnavoxhelp.com for instuctions.
Posted on Jun 26, 2008
Why does blower work when pulled out but not in place.
Something binding the fan when installed.
Aug 18, 2016 | 2001 Ford Focus
Troubleshooting crosley dryer thermal fuse
Hello - Usually this type of information is not release to someone who is not a technician (or to a consumer) and it is very rare to find enough information to do it yourself. In most cases this information can be found on the internet; however it is not provided directly from the manufacturer. Typically this is something that you want a certified professional to install/remove for you due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area can properly repair/install this part. (part usually have a 30 day warranty with tech). I would suggest contacting your manufacturer to provide you a listing of authorized technicians in your area whom may guide you through this process.
Dec 09, 2012 | Crosley CDE6000 Electric Dryer
My Kettler cross trainer Mondeo gives me program error E2 on the display. Kettler has cleverly hidden any information about what this actually means (so I can fix it). Thanks for any help you can...
E-2 FAULTS ARE PROBABLY DUE TO A FAULTY CONNECTION BETWEEN THE CONNECTING PLUGS-MINE WAS,I CHANGED A LEAD IN THE END AND SOLVED THE PROBLEM.PLEASE SEE MY POST ON THIS SITE ON THIS MATTER. MARK DAVIES
May 22, 2011 | Kettler Mondeo Elliptical Trainer
:( the phone got reset and its struck with the screen... i cant tap it help me out
One thing that you can do to try to resolve this issue is to take the battery out while the phone is on. This is called a hard shock and will not damage the device. I was a tech trainer for at&t for several years and this is a common troubleshooting technique. If this does not work and the device is under a year old, I would advise you to contact your wireless provider as the handset is under a 1 year warranty from the manufacturer and they will usually replace it at no cost. The down side is that you will lose all of your pictures, games and ringtones if you have any. I hope that you have found this information useful as that is my goal.
Jan 18, 2011 | Samsung SGH-A877 Impression Cell Phone
Weld on left leg broke. How do i get a new one?
hello j ing...... If your trainer is less than one year old contact the place where you bought it. It should still be under warranty. IF not, your best bet is to have that break welded at a local welding shop or auto body shop. Look in the phone book and call around to see who will weld it for you and how much it will cost. Generally, a repair like this will cost between $20 and $40.
Joe
Thanks for choosing Fixya!
Dec 20, 2010 | Endurance E7 Elliptical Trainer
Trying to scan (has previously worked), now it says waiting for PC...then does nothing. I have rebooted both the computer and printer. No luck
Check the cable. Check the settings here. See the general troubleshooting section of this article. Here's a link (and here) to many typical error messages for your printer, though I can't reference your "waiting for PC" message. Troubleshoot the network here., and print a network configuration page to check for errors here.
Hopefully something there will strike a chord.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 25, 2009 | HP LaserJet 2840 Printer
Lost instructions for Rober Black cross trainer
Hi, I have bought a second hand roger black silver cross trainer and I do not have any instructions, also the bolt that holds the front post together is missing and the tension dial does not seem to work can I adjust the tension in side the front post! Please can you help. Kind Regards Janet
Feb 01, 2009 | Exercise & Fitness
Hello
Please consult this article from Microsoft to take steps to improve your system's performance with Vista, by clicking here
For troubleshooting performance issues, please see these articles and the links within them: TroubleshootVistaPerformance and Troubleshoot Vista Startup and Vista Diagnostics
Finally, you may wish to consult this General Setup&Maintenance guide.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Dec 08, 2007 | Microsoft Windows Vista Ultimate Edition
Philips 50P8341 50" Rear Projection Television Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
