Monitor YOu did great on my last problem, thanks! Now, is there a way to cut this monitor off without shuting down my computer?
  • 667 Answers
Hi armstrongmac - I can help you out with that. If your running Windows, go to start>control panel>performance and maintenance>power options. There you can set the monitor to turn off after you haven't used the pc for x amount of time. Just moving the mouse or pressing a key will bring it back on.
If your running Vista, go to your search box, type control panel, then click on power options and you'll be able to do the same thing. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a great day.
Jeff
Posted on Jun 05, 2008
Last night I cut my computer off and it froze on the shutting down screen so I held down the power button and it cut off. Now when I cut it on the light on the monitor is orange. It's Gateway 817GM. Help?
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Jun 27, 2014 | Computers & Internet
Dell dimension 370 randomly shuts down orange light flashes on pwr button
I suspect your graphics card or processor is overheating and shutting itself off to prevent damage.
Cool the unit down with additional fans, introducing cool air and exhausting warm air is key to a reliable, stable computer system.
The reason for this sudden problem is most likely because a higher resolution on the new monitor is supported, therefore making the computer work much harder than before.
Take care!
damnor01
Jun 09, 2012 | Dell Dimension Computers & Internet
Monitor works intermittently
Hi Michael, it does sound like the monitor then. The most likely cause is bad capacitors in the power supply. Typically a cheap repair but you do have to solder and such. Unless you have to have a very expensive monitor its probably better to just replace it since basic monitors are so cheap these days. Good luck.
Feb 22, 2012 | Gateway FPD2185W 21 in. LCD Television
My 20 inch Dell Monitor keeps shutting down..
mcdevito75 here, Sounds like the monitor itself, contact Dell for rep[lacement on warrantee if warrantee applies.
Jul 14, 2010 | Dell ST2010 20" Monitor
My computer keep shuting saying monitor going to
start button >settings >control panel > Power Option > set time for monitor to sleep if inactive...if you dont want the computer to sleep go up to the hibernate tab and uncheck it. If you want the computer to stay on regardless, move all drop down menus to "never" instead of a time.
Sep 01, 2009 | HP w1907 LCD Monitor
Monitor won't turn on without help.
Do you have a second monitor or can you borrow one to check if the fault lies with the monitor or the PC?
If the monitor is at fault then there is not much you can do yourself. I suggest you contact Dell and get them to replace it under warranty. Most LCD monitors have a 3 year warrantly, at least they do in the UK.
cheers
Aug 04, 2008 | Dell E177FP LCD Monitor
ACER AL2216W shuted down
I had a similar experience to yours with my AL2223W. I found this site helpful in replacing my backlight inverter - http://www.instructables.com/id/Replace-LCD-Backlight-Inverter-on-Any-Monitor-for-/
Hope this helps,
Observative
May 30, 2008 | Acer AL2216WBD LCD Monitor
"Auto" always worked but now messed up; can't fix
I had same problem and eventually it died after degrading further a few months later. Other monitor works great...
Oct 27, 2007 | Videoseven V7 R19WPS 19" LCD Monitor
Sound Cutting Out
If you looked for dry connections and found none, there is probably a componet that is intermittant, and these can be tough puppies to troubleshoot, without monitoring the power supply voltages and sittinfg with the unit.
Jan 04, 2007 | Philips LX3000D System
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
