Sharp PG-C20XU, no power light
Experts,
I do not have a power light, nor any indication that the LCD is on in any way. Just making sure that this problem is the power supply gone bad or could this be caused by something esle. I have change out the plug and ensured that the side vent cap is closed.
  • 2,237 Answers
It may be the bimetal breaker. you'll have to open the case and reset it. it's the red button on the front of the lamp housing.
Posted on Dec 23, 2009
Projector only showing background of computer
1,check the interface of the input port
2,change the solution of the computer, you can change to 800*600 ...
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 29, 2014 | Sharp Notevision PG-C20XU Multimedia...
Replace an existing bulb in an existing bulb cage.
it's always best not to go with the cheapest price online. you'll have to remove the screws and brackets holding the bell on, and the screw holding the plug on. if the new one didn't come with a plug, remove the plug wires from the old lamp. reverse process to install. but be careful not to overtighten, or you'll crack the bell.
Feb 02, 2010 | Sharp Notevision PG-C20XU Multimedia...
After filter cleaning of a Sharp Notevision PG-B10S arose the following trouble: I turn the power on, during the warming up the stanby and power buttons go to green light, then after 10 seconds the power...
If you navigate through the projector menu you will most likely find an option to reset the filter timer. Resetting the timer will cause the indicator light to stop blinking.
Jan 18, 2010 | Sharp Notevision PG-B10S Multimedia...
Dear expert my projector tv when I turn the projector on the buttons turn red on the tv and it refuses to come on. Whar do you think is the problem?
if the fans come on and no light, it's either the lamp or the ballast that needs to be replaced. check the lamp. if the inside has bulges, black spots or fogging, replace the lamp. you can get the part from a sharp service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 15, 2010 | Sharp Notevision PG-C20XU Multimedia...
THE LAMP DOES NOT COME ON AND THE LAMP LIGHT BLINKS
New projector lamp time! you may have found that a symbol of a lamp comes on in the bottom corner of the picture after you turn it on for a short time. perhaps the lamp light has been flashing too. But yourself a lamp and be sure to follow the instructions that come with the lamp on resetting the timer- you must do this in order to get it to fire up again. Tip for the Sharps- Must replace it with the AC cord disconnected. (reconnecting the AC cord is part of the reset procedure)
Happy lamp shopping!
Jan 11, 2010 | Sharp (BQC-PGC20X//1) Projector Lamp for...
Sharp projector - problem, can't reset lamp timer
You must use the remote as well!
Plug the power cord into the AC
socket of the projector
1 Press KEYSTONE ' and
KEYSTONE " on the projector at
the same time.
2 Press INPUT and AUTO SYNC on
the projector at the same time.
3 Press AUTO SYNC and MENU at
the same time until unit comes on
LAMP 0000H is
displayed, indicating that
the lamp timer is reset.
Aug 20, 2017 | Sharp (BQCPGC20X1) Projector Lamp for...
PG-C45X projector wont power on
To solve this problem, simultaneously press the "Input", "Enter", and "Undo" buttons. While holding these buttons, press "On". When the project turns on, you should see "LAMP 100%". This indicates that you have successfully reset the lamp life timer.
Nov 17, 2008 | Sharp (BQCXGC50X1) Projector Lamp for...
LCD overheats then the lamp turns out
clean all filter and do not block any ventilation slots with any objects and check .if the problem exist contact service center for help.
Mar 19, 2008 | Sharp Notevision PG-C20XU Multimedia...
149 people viewed this question
k24674
jasbo
jasbo
