Question about Whirlpool LER3622HQ Electric Portable Dryer
Loud noise I have a Whirlpool electric portable dryer. It turnes on and the drum spins but there is an extremely loud humming noise while it is spinning. Please help?!?!
  • 868 Answers
You may have something stuck on the blower wheel
Posted on Jun 03, 2008
Whirlpool dryer was making loud squeaking noise. Now it is not turning at all. Makes a noise when you turn it on, but stops completely.
Check the drum belt. Check the drum rollers on the back & glides on the front that the drum rides on also check the idler pully. Check the felt the drum rides on in case it came loose and won't let the drum turn. Did it hum when you started it if so could be the motor. Good luck
Apr 06, 2014 | Whirlpool GGW9200L Gas Dryer
My whirlpool electric dryer makes a loud grinding noise
Is there anything caught between the dryer drum and any housing. Can you hear it when the drum is turned by hand.
Jan 26, 2014 | Whirlpool Dryers
Loud humming or buzzing only when it spins at high speeds
This noise causes by the drum bearing is getting worse. As soon as the noise is getting far louder and extremely louder then you have to replace the bearing of the outer drum. Normally, the repair cost is as high as buying a good deal new washer.
Oct 14, 2013 | Whirlpool Duet 4.0 cu. ft. Washer
My whirlpool ler4634 electric dryer has electricity running to it but when turned on, the drum does not rotate. It only makes a loud humming noise. What can be the problem?
It sounds like you have a blown motot try holding down the door switch and push start and turn drum at same time see if it kicks in
Sep 22, 2010 | Whirlpool LER4634J Electric Dryer
Drum not turning, hear humming noise
the humming noise is from the motor,see if you can spin the drum by hand,if it moves you have a bad motor,if it's hard to turn you could have something stuck in the blower wheel or the belt is jammed somewhere,the blower wheel is behind the duct that the lint filter slides into
Mar 20, 2010 | Whirlpool LER4634J Electric Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Dryer won't spin, but heats up - belt is okay
the motor may have seized up, or the drum bearings are shot.
Jun 19, 2009 | GE DBL333EA Electric Dryer
Dryer Not Tumbling
Sounds like belt problems.
Jan 20, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool LER3622HQ Electric Portable Dryer Logo
134 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
