Question about Canon NP 6050 Copier
Cannon np 4050
We have a cannon np 4050 at work and it ask give us a error E020 can someone help me!!!!!!!
  • 3 more comments
  • WVF_32000 Jul 09, 2008
    I HAVE THE E020 CODE AND I DONT KNOW HOW TO GET INTO THE SERVICE MODE? I TURNED IT ON AND OFF BUT STILL THE SAME CODE AND NO KEYS FUNCTION TO SCROLL. I CHECKED THE TONER AND IT IS ABOVE HALF BUT I ALSO DONT HEAR THE MOTOR SOUND THAT IS NORMALLY HEARD AFTER TURN ON. ANY HELP ? WOULD BE GREAT
  • ranger4lord Feb 05, 2009
    i have same problem and i need to find out how to empty hopper. I have canon 4050 with error code e020
  • Anonymous Mar 17, 2014
    canon np 4050 toner adjust
    canon np 4050 toner not servise
    canon np 4050 toner empty
The toner is not adding correctly into the developing assembly. 1) If toner hopper is overfilled, the toner motor worm gear splits as a result of the hopper becoming packed tight. 2) Sometimes the worm gear splits under normal use.
Posted on Jun 03, 2008
Canon np 4050 eror cod e020
e0020
the toner does not move down.
the problem possibility :
- motor of toner not moving and can not pull down the toner
- sensor of toner no detect (check the socket of it perhaps it's just loosen)
- or empty toner.
May 25, 2011 | Office Equipment & Supplies
E10 falt 4050 cannon machine
check main motor, motor control board, check if paper pick up unit is jammed or fixing is jammed any kind of moving part jam can cause error e10
Dec 26, 2010 | Canon NP 6050 Copier
My copier was relocated. now the error code E020 displayes on the screen. What does this mean?
CHECK THE HOPPER MOTOR MAYBE THATS NOT WORKING THATS WHY ERROR E020 APPEAR BECAUSE THE TONER FROM HOPPER ASSEMBLY IS GOING TO THE DEVELOPING UNIT
Feb 04, 2010 | Canon NP 6551 Black and White Copier
Er e020
Hello
E020 means :
"Black toner motor" so check it.
Jan 20, 2009 | Canon NP 6050 Copier
Canon NP 6545 - Error E020
E020 try by push reset button until show $ upper left
then press key *4* and you will in service mode.
find code error 1 in LCD then press *
copier will restart.
Jan 12, 2009 | Canon NP 6545 Copier
CANON 4050 XEROX MACHINE
my xerox machine canon 4050 shown an eroor(E020)...we cant able to take copier
Oct 16, 2008 | Canon NP 6050 Copier
Canon NP 6050 copier Error
E020 is a toner hopper motor error. This means that not enough toner is being sent to the developer box. It usually is a hard error, meaning that the part has to be changed.
Jun 30, 2008 | Canon NP 6050 Copier
Canon np 4050 low fusing temperature
I am not 100 percent sure what is happening to your machine after it comes to ready, but I will offer some thoghts.
If it comes to ready and then goes back to a low heat situation. It very well could be the board if it doesnt maintain heat.
Now that being said, once a coiper comes to ready and reaches full heat, it will switch over to pulsating the heat roller, not staying on fully all the time. That is how fusers are designed. Full on until they reach operating temperature, then pulsating to maintain the rollers heat level.
If you are having a problem with the image not fusing to the paper, you may have an issue with the pressure roller not making good contact with the heat roller.
There may be a software setting that needs adjusted to increase the fuser operating temperature.
The flickering heat rod, once the machine reaches ready, seems appropriate.
If you want more of an idea, can you be more specific as to whether the machine is faulting out with an under heating situation, or is the image not fusing to the paper properly?
Dec 07, 2007 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
261 people viewed this question
old marine
old marine
