Question about Indesit W 123 Front Load Washer
Indesit. where is the filter on this machine My built in, indesit wm 12 washer won't drain. I need to clean the fluff/lint fron the filter. The circular collector thingy on the bottem, right hand side of my washer wont unscrew. Any tips please???
  • 734 Answers
Hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
Does this machine have a fluff filter? Ive never had a washer dryer before. Always had a fluff filter in my dryer
I've never heard of a fluff filter but I know it has a lint screen that needs to be cleaned at least every 3rd load or so for peak performance.
May 02, 2016 | Washing Machines
Is there a filter to catch fluff during wash?
How to Reduce Lint in Laundry - Home Ec 101
www.home-ec101.com/how-to-reduce-lint/
Sep 23, 2010 - I clean out the dryer lint trap every time and that doesn't seem to matter. ... If your washing machine is older, there is a chance that it has a built-in lint trap. If this is the case and ... Follow the directions for cleaning the lint filter.
Washing Machine Pump Filter - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 8, 2013 - Common problems and faults with a washing machine pump filter. ... a pump filter to protect the pump from a build up of lint, and obstructions such as coins. ... towel to catch water and don't take it out at all if the washing machine still ... If you can't see any blockage, or there is just the odd button in there that ...
Is there a filter to catch fluff during wash? - Fixya
www.fixya.com/support/t26006809-filter_catch_fluff_during_wash
3 hours ago - Locating fluff filter on aeg washer/dryer . After using the dryer facility the following wash resulted in garment containing patched of fluff ...
How To Clean Your Washing Machine Filter - YouTube
Dec 13, 2015 | Washing Machines
INDESIT IWDE12 DRYER NOT WORKING LIGHTS FLASHING IS IT FLUFF FILTER? WHERE IS FLUFF FILTER
Combined washer/dryer? If just dryer it's surely just 'down the front?
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 26, 2011 | Washing Machines
My washer isn't working the washer is an LG TROM WM2277HB the washer shows OC I don't know what that means
Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
Aug 28, 2010 | LG WM-2277HW Front Load Washer
Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
Do I need to drain my LG washer at regular intervals?
no you shouldnt unless you put to much soap in it
Apr 24, 2009 | LG WM-2277HW Front Load Washer
Drsining washer manually
open the little door at the bottom fron and twist open the lint filter clean out
Jul 12, 2008 | Miele Touchtronic W1113 Washing Machine
Indesit.
Most Indesit washing machines have hidden filters and are not meant to be customer accessible. If you are referring to the incoming water supply, then in some models, it would be immediately after the connector; if on the other hand, you are referring to the lint/fluff collector/filer, then there is no real filter but rather is a part of the drain system. Normally it is at the very bottom of the machine. You need to remove the lower front panel. There would be 3 clips that holds it in place. Once the inside is exposed, there would be a black circular cover at the right hand side. Unscrew it out and clean the inside. It would normally be filled with water and some other "stuff" so pls have cleaning materials handy and/or anything to absorb the spilling water.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 24, 2008 | Indesit W 123 Front Load Washer
Whirlpool top loader 9 kg - I can't see any serial no.
There are no lint filters on this machine. The lint is pumped out with the water. There may be a restriction in the drain line starting where it connects to the tub or the small drain holes in the inner tub may be clogged.
Jan 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Indesit wi 121
pull out the part you have been turning and it unscrews and the filter pulls out. it should not be smelly.if you are using liquid detergent, this will cause the smell. some water will come out when you remove filter but not huge amounts assuming the machune has drained properly
May 19, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
129 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
