Question about Ricoh FAX3900L Plain Paper Laser
Ricoh fax 3310 transmitting problem
How do you turn the baud rate down on this machine
    Problem Solver:
  • 13 Answers
It steps down automatically.
Posted on Aug 28, 2008
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Change baud rate for brother fax
  • Press Stop/Exit.
Change baud rate on okifax 5050
The baud rate is automatically set by the machine when it connects to the remote machine. The machines start at the highest speed and drop down until both machines can send/receive without any errors then they send the pages. You can not manually set the speed.
Buddymc
Feb 27, 2012 | OKI Office Equipment & Supplies
Kyocera KM-3050 - Faxing error code
Try calling that number from a regular phone and listen for fax tones...it may not be a fax number.
Oct 15, 2009 | Kyocera Office Equipment & Supplies
Ricoh Afcia 1013F Need to change Modem Speed for Use with VoIP
That fax modem isn't compatible with VoIP. You need a seperate analog phone line to get it to work.
The maximum baud rate for faxing on that machine is 9600kbps.
Oct 15, 2008 | Ricoh Aficio 1013F Copier
Change baud rate
Baud Rate is to lower the transmission speed of the fax, however these are the temp settings and once the power is off you have to reconfigure that. Follow the following steps :
From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
    1. Enter the parameter ____ on the key board and press the Check Mark.
    1. 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    1. The screen will read Cfg param val: 26
    1. Enter in the value ____ and then press the Check Mark .
    1. 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    1. Screen will read Test -001+
    2. Press the Reset button until you get back to Ready
    Dec 13, 2007 | HP OfficeJet D135 All-In-One InkJet...
    Ricoh FAX3900L Plain Paper Laser Logo
    304 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    quennie732
    OfficeServiceAjnc
    OfficeServiceAjnc
    Bernard D'Souza
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
