Question about Sharp Kitchen Ranges
Sharp KB-3401LW 30 Insight Electric Range. On the glass touch control panel I can only see portions of the digits. All digits are not fully showing.
  • 868 Answers
Either your clock has slipped inside and you can easily re mount it,or replace the clock.
Posted on Jun 04, 2008
Can your microwave work without mica cover?
It can be, but it's not recommended. Food can splatter and get into the waveguide and cause problems. Also if you reach in there with your finger right after the microwave stops, you can get a severe shock (until the capacitor discharges, usually in about a minute). Also the edge is sharp.
Nov 07, 2014 | Sharp KB-4425LW Insight Pro Electric...
Sharp insight glass ceramic cooktop, with a cracked glass. I need to replace the glass ceramic cooktop. Model kb 3300 js .... serial 112895. Will be shipped to Puerto Rico.
You can buy the substitution replacement part at searspartsdirect.com for $711.99 (price on 1/29/2011). This is a manufacturer authorized substitution part. I pasted the note about those. We need to purchase one too, but are searching for something less expensive. If we are unable to locate a less expensive option we will probably just buy a new stove, because the replacement cooktop costs almost as much as we paid for our unit when it was new. We are looking at a possible part from sharp for another unit which maybe compatible...if it is it would be $296 before s/h, etc. That is a better price, but still more than I would like to pay for a piece of ceramic glass.
Manufacturer authorized substitution: FANG-B022MRY0 may differ in appearance, but is a functional equivalent to prior parts including FANG-B001MRY0.
Glass assemblyNumber:FANG-B001MRY0Substitution:FANG-B022MRY0
Jan 15, 2011 | Sharp KB3300JS Stainless Steel Electric...
Self cleaning keeps popping up beeping with F5
Hello,the F5 beeping is all about the Push button stuck.
Check for the binding of Push button and control panel glass.If OK,replace the touch panel.
Thanks
Jun 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The moonroof on my 2002 lincoln towncar is stuck open. I can hear the motor when I push the open button, but the motor sounds dead when I try to push the button to close. Could it be jammed? Is there a...
Temporary Fix: unsnap off the access door in the overhead ceiling liner behind the sunroof opening;
Use a 4mm hexagon Allen wrench to wind it closed.
Sep 12, 2009 | 1999 Lincoln Town Car
Sunroof doesn"t open or close
Section 01-17: Roof Panel, Sliding—Electric 1996 Taurus, Sable Workshop Manual DESCRIPTION AND OPERATION Electric Operation The sliding roof panel (502B98):
  • is available as an option.
  • is electrically operated through the accessory delay relay (controlled by generic electronic module (GEM)).
  • is of self-storing design.
  • requires a specific headliner.
  • utilizes a unique roof console and dome lamp.
  • has an air deflector.
The electrical system operates in the following manner:
  • Two switches control movement of the roof panel.
  • When the SLIDE roof sliding panel switch (15B691) is rocked rearward, the roof sliding outer glass panel (502A82) slides into the storage space between the roof trim panel (51968) and the roof panel, exposing an opening over the front seats.
  • When the SLIDE roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully back in the storage space, the roof sliding outer glass panel moves forward from the storage position.
  • The rear portion of the roof sliding outer glass panel moves upward on two lifter arms near the end of the forward travel, allowing a weather-tight seal when the roof sliding outer glass panel is closed.
  • An AUTO feature allows the SLIDE roof sliding panel switch to be touched momentarily to cause the roof panel to automatically move to the fully open position.
  • When the TILT roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully forward, the rear of the roof sliding outer glass panel pops up to the VENT position.
  • With the roof sliding outer glass panel in the VENT position, rocking the TILT roof sliding panel switch rearward closes the roof sliding outer glass panel.
  • Sliding Roof Panel Does Not Open or Close
  • Open power feed fuse.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged roof panel
  • Obstructed roof panel
  • Guide
  • Damaged drive cable(s)
  • Open Power Distribution Box Fuses 1 (40A) or 4 (30A)
Apr 19, 2009 | 1996 Ford Taurus
Wave touch panel comes out of sleep mode by itself
Your range should have a two year part and labor warranty so contact Electrolux to schedule service. They will preorder and ship you the parts prior to a servicer arriving.
Mar 21, 2009 | Electrolux EW30ES65GS 30" Slide-in...
Where is the fuse panel located in Frigidaire Professional Series Slide in Cooktop range?
I can help , The fuse panel/control board is located behind the digital display in the front of the unit. Some drop in ranges are tricky getting into so be carefull when removing the face , there are screws under the display when opening the oven door look up and there may be a few more on the top side corners reveled when you pull the unit out 12" or so. there is a small glass fuse in the board some of these are not removable so if there is no digital display on your oven and your sure you have 240V to control board you will need to replace the entire control board. Hope this gets you there. Good luck let me know if you have anymore problems.
Phil
Dec 31, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
Kenmore Electric oven 91141065791
Failure
Code
Condition Check/Repair F2 Oven temperature above specifications 8-pin connector oven temperature sensor to the Electronic Range Control (ERC) F3 Open oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F4 Shorted oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F5 Pushbutton stuck Check for binding of pushbuttons and control panel glass. If OK, replace touch panel F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC) F7 Computer logic interrupted (lock motor) Replace Electronic Range Control (ERC) F8 Computer logic interrupted Replace Electronic Range Control (ERC)
Oct 23, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
103 people viewed this question
Top Sharp Kitchen Ranges Experts
William Miller
William Miller
Richard Lane
 John
John
Are you a Sharp Kitchen Range Expert? Answer questions, earn points and help others
