Question about Sharp R-242 Microwave Oven
Sharp Microwave R-950A
When Preheating oven on convection to say 200c does not stop or give signal,just gets very hot and then display goes dead.after +-5mins display comes back on.
  • 1 more comment
  • charles54 Jun 12, 2008
    Thankyou so much for your help , am waiting for part to arrive will tell you if that was the fix
    regards
  • charles54 Jun 25, 2008
    Thankyou so much for your help,i have got the part and replaced thermistor and microwave is fixed
    thankyou once again
    regards
    Charles
  • Anonymous Mar 17, 2014
    display is very dim. Sometimes it comes on bright but then goes very dim again
  • Sharp Master
  • 9,098 Answers
Chances are your thermistor is defective.
This UK model is probably similar to the US model R-930 or R-820.
We have both service manuals at our site and while the part numbers will not necessarily be the same, they will be handy for safety, disassembly and troubleshooting. They are here and here.
When you're ready to order parts, visit Sharp UK for spares dealers and servicers.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
Sharp carousel microwave convection oven keeps blowing fuse
The service manual is here:
http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
You can get Sharp parts from Encompass here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
See http://www.microtechfactoryservice.com/cap_test.html
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
See: http://www.microtechfactoryservice.com/xformer.html
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
See this: http://031d26d.namesecurehost.com/mwd/doorsw.txt
Aug 01, 2013 | Sharp R-820BK Microwave Convection Oven,...
Sharp carousel convection/grill/microwave maybe R990
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Jun 03, 2010 | Panasonic NN-S254BF Microwave Oven
R9H84B Sharp Microwave Convection from 6-6-1997, power stopped and turntable stopped. Light works and sounds like the power is working but nothing gets hot.
Is this the unit with the door that swings down like a conventional oven?? I think it is. This sounds like a door switch but could be a magnetron or cook relay on the control PCB.
Sep 11, 2009 | Sharp R-9H84B Microwave Oven
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp r96st stops at 1 sec and halts whilst preheating oven
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
Jan 29, 2009 | Sharp R-1480 Microwave Oven
Microwave Key Pad stopped working
buy a new one they are not expensive wal-mart has 1000w for about 80 bucks
Jan 25, 2009 | Sharp R-1874 Convection/Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Dec 11, 2007 | Sharp R-510HW Microwave Oven
Sharp R-242 Microwave Oven Logo
190 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
