Question about Dell Computers & Internet
Sound problems.. I have a dell xps m1330 which is always connected to a set of logitech speakers. i recently discovered that when i'm playing songs through the laptop, the bass becomes very very soft. I can only hear the bass at a comfortable level when i turn it all the way up (which under normal circumstances would be blowing the roof off). I tried to connect my ipod to the speakers, and it works find. Is there something wrong with my laptop's sound card or something? or is there some settings that i need to attend to? thanks
    Guru:
  • 61 Answers
I recently reinstalled my Vista OS on a Dell XPS m1330 laptop, and now I cannot connect to a second monitor, nor will the built-in speakers make sound. The only monitor option available in Display Settings...
You need to check the device manager for any "!" symbols. They are most likely there for your audio and video drivers. This means that the current drivers installed are not compatible. See below for the correct drivers.
Vista 32bit
Vista 64bit
Dec 02, 2010 | Dell XPS M1330 Notebook
My dell xps m1330 speakers are not working. My earphones are working but not the speakers. please help
if the operating system is vista or Win7 then go to sound then under that u will see speakers then click on speakers and then click on Set as Default. This should fix it .
Aug 14, 2010 | Dell XPS M1330 Notebook
Internal Connection of Built In Microphones on the
go to control panel- sound and audio devices- click the voice tab- click on the "test hardware button"
follow the prompts. if it tests ok there and still doesnt work in something like skype, then you'll need to go through the settings OR setup wizard in skype in this example and choose the internal mic instead of the external which isn't there.
Apr 04, 2010 | Dell XPS M1330 Notebook
My Dell XPS M1330's internal speakers are not working, the audio utility claims that it is producing sound. I am running windows vista, and the sigma tel audio codec is my sound driver.
#1 Flash the BIOS to the most current version. #2 Run diagnostics from the F12 menu (Or Power plus FN key) see if the speakers work in the diagnostic. If they work in diags, there is no hardware issue, only a software issue. If you get no sound in diags, try a pair of headphones, if you still get no sound, then it is a hardware problem. If you only get sound in the headphones, then the microswitch that disables the speakers is stuck. #3 is sound works in diags then you have a problem with the audio driver or speaker configuration (Audio muted etc)
Jan 06, 2010 | Dell XPS M1330 Notebook
My dell xps m1330 used to play dvds just fine until recently when all of a sudden the picture was still fine, but the sound was disrupting and breaking up.this has happened once before, but after a week...
try to restore windows to the point when it was working fine with the audio. check if this fix the problem if not then do a clean install of your windows. make sure to back up files first.
Oct 14, 2009 | Dell XPS M1330 Laptop
How to change speakers on xps m1330 laptop
The internal speakers I presume. Essentially you have to completely disassemble the system. Remove the battery, all drives, central control cover, LCD, Keyboard, Palmrest, Card cage and motherboard to get to the speakers in the bottom back of the chassis.
http://support.dell.com/support/edocs/systems/xpsM1330/en/sm/speaker.htm#wp1038494
Sep 05, 2009 | Dell XPS M1330 Notebook
Dell XPS M1330 PC Notebook can't connect to the external monitor
No. You just basically need a VGA cable. Check your video settings.
May 06, 2009 | Dell XPS M1330 Notebook
Touch pad
HI,
The xps 1330 is known to have problems with the internal speakers. Kindly call Dell Tech support and get the same replaced,while your system is under warranty. The cable that connects the speakers inside is either not connected right or is broken. If you are geeting sound form the headphones , your soundcard is fine , and there is no software problem on the system.
Thanks
mandeep
Jun 09, 2008 | Dell XPS M1330 Laptop
Computers & Internet Logo
83 people viewed this question
Alun Cox
