Question about HP Photosmart C6180 All-In-One InkJet Printer
Single black line down center of newly copied page when using Auto feeder to copy
When using auto feeder to copy mutiple pages, each copied page ends up with a single black line about 3" from the left edge of paper. This line appears the full lenght of the paper.
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Posted on Jun 05, 2008
When using the auto feed, copies come out with black streaks down center of page
If you only get streaks when using the automatic document feeder, then in most cases it is dirt on the scanner glass. You do not state model but if you can also scan flat objects, trying copying a piece of paper that way. If that copy comes out fine, then you definitely have dirty glasss, if that copy has streaks you either have dirt on the scanner itself or a faulty scanner unit.
May 08, 2015 | Office Equipment & Supplies
Auto Document Feeder copier problems
The scanning glass probably needs cleaning.
Jul 31, 2009 | Epson ACULASER CX11NF All-In-One Printer
Vertical line down all copies coming from the top multipage feeder.
Please provide model number......however, if it's a "copier style" if you open the auto feeder, there should be a large contact glass and then a small "****" glass on the side that is used when using the auto feeder -clean this glass thoroughly (clean both while you're at it). If it's just a regular style fax machine, there will just be a small glass under the cover that needs to be cleaned.
Please let me know :)
Apr 21, 2009 | Office Equipment & Supplies
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Hp laserjet 3050 - black line down the center of copies, everything elese works
If the lines only appear on copies from the auto feeder and printing is clean, then lift the auto feeder section and clean the scanner glass underneath.
If printing and copying have similar 'streaky' results you probably have a bad toner cartridge - try a replacement. If that doesn't work you have a fuser problem - which is quite a costly repair based on the replacement cost of your unit
Feb 26, 2009 | HP LaserJet 3050 All-In-One Printer
MFC-9440 CN--Lines in my auto feed scanned/faxed copies
clean the thin strip of glass located under the document feeder with something non abrasive
Feb 06, 2009 | Brother MFC-9440CN Laser Printer
Full page vertical line appears on copy fed pages.
Open up the document feeder. You will probably find wite-out on the scanner glass.
Dec 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Black Line Down Center of Page
I had the same problem. I cleaned the strip above the glass and this fixed the problem. Hope it helps!
Feb 14, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Black line when scanning though auto feeder
pls clean the side glas of scnner with tissue paper ther is two type of glass is there one is a4 size and second is normal slim one so pls clean the slim one with wet tissue paper and see is ti clean .
bye
Nov 05, 2007 | HP Photosmart C6180 All-In-One InkJet...
LINES DOWN THE PAGE WHEN I USE AUTO FEEDER
sounds like you need to do a head cleaning. go to control panel on computer and click on faxes and copiers. right click on the printer you are have problems with and there will be a head clean and nozzle check choice run through those.
Oct 13, 2007 | HP OfficeJet D135 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
585 people viewed this question
Seeker5211
Seeker5211
