Service code SC546 on a Ricoh Aficio 1045
My Ricoh Aficio 1045 Digital mult-function copier is showing a SC 546 service code
  • 3 more comments
  • Anonymous Jun 26, 2008
    tengo problema sc546 de una copidora ricoh 1045, agradezco su colaboracion, gracias
  • mararroba Aug 08, 2008
    hallo do you know what part shall i change thanks
  • jcw1 Oct 06, 2008
    What do I need to do? Replace a part, call a tech, or throw the unit away?
  • Anonymous Apr 13, 2009
    i have problem of sc 546 code
  • Anonymous Mar 14, 2014
    i have problem to ricoh 3045 model photocopier machine,showing the error code Sc 878.tell me the solution.
  • 3 Answers
Try to go into service mode to reset the code...
Clear yellow botton
7
then press and hold the red stop botton till the display changes and then turn the main Power switch Off then back ON... You do not have to do any thing in service mode, just get to that display.... Don't change anything unless you know what you are doing. sc546 has to do with the fixing unit. You may be able to reset it.
Posted on Dec 14, 2009
Michael sinaon
press and hold yellow botton then press 1 0 7 then press and hold red stop untill the sp mode is appears in the screen then chose drum,then off,,,and on
Posted on Apr 27, 2010
Sc 990 and when copy too much will be not clear as before hope will help me ps
Posted on Sep 27, 2008
Sc990
Posted on Aug 14, 2008
This is usually caused by the fuser not reaching the correct temperature in which case you would need to get it repaired.
Posted on Aug 01, 2008
How do ican clear sc546 error in sp4100n printer?
This was already answered by mncomputer here on FixYa:
"Turn the machine off, hold down online & escape, turn machine on and wait for "1.Service Menu" Select service menu, find sp 5-810, select #/enter, when it says "execute select #/enter, then escape. Turn machine off then on."
How reset error sc 546 on ricoh aficio 4100n
Nov 24, 2014 | Office Equipment & Supplies
Functional problem sc546
sc 546 is a fusing related code. either the fusing lamp or the thermostat is blown out. one of them needs replacing
Oct 01, 2010 | Ricoh Aficio 150 Copier
SC546
sc 546 is fuser fault!check the connection of fuser catridge or try this:turn on machine-enter the servicemenu-open front door-then power on/off-close front door---->this will restart your Ricoh
Apr 06, 2010 | Ricoh Aficio 1035 Copier
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
I have a Savin 9922DP red wrench and code SC 546
Parts availability ended for this machine Jan of 07, now is a good time just to chuck it.
Jun 02, 2009 | Ricoh Aficio 450 Copier
Fault SC546
SC-546 is "Warm-up" error, suggests that the fuser is NOT reaching 160' within standard warmup time.
You might be able to take out the fuser, remove fuser cover, remove carbon buildup from thermistor.
I had to change our fuser at 180,000 copies (service is at 120,000)
Jan 12, 2009 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
TECH SUPPORT
Possible solution: Remove fuser cover, remove carbon buildup from thermistor.
I had to replace the fuser unit but it had 180,000 copies - service is 120,000
Aug 01, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Computers & Internet Logo
7,156 people viewed this question
David Payne
David Payne
