Question about Ovens
Tappan gas stove,oven not lighting
All four top burners work.oven igniter doesn't work and their is no smell of gas,any ideas?
  • 3 more comments
  • sommerrain Jun 09, 2008
    I have a tappan stove... we are unable to light the stove and oven without the use of matches! Help please what could be the issue.
  • isaacsped Sep 11, 2008
    I used my oven on yesterday morning. By evening, the oven would not light. Is it possible that the oven timer could cause this problem?
  • fabivane Oct 16, 2008
    Oven is not working /no gas smell or nothing , I was told that it was the" electronicc cloc control" . If this is the case why does the time clock is working fine? some one please help me we will need oven for Thank's Giving Day .HELP GURU
  • Anonymous Dec 23, 2008
  • Anonymous Mar 14, 2014
    need the installation manual
I am unable to use my oven on my tappan gas range. every other part of the range works wonderfully. the oven just will not light
Posted on Sep 11, 2008
    President:
  • 1,314 Answers
Yes replace the lower oven ig nighter you can do this from inside the oven pull the racks out then locate two screws in the bottom oven pan take the out pull the bottom plate then pull the flame spredder pan and you will see the glow bar replace that most common for you compliant
Posted on Jun 05, 2008
My oven is not working. At the bottom of the stove the ignitor light comes on, but gas doesn't come on. I would like to fix the problem, can you instruct me on how to fix my oven. I want to bake...
The ignitor is probably weak. You have a good circuit because the oven control is trying to light burner. The gas valve is alo fine because it is allowing current to flow. The ignitor with age does not draw enough current to light off the stove.
Aug 23, 2011 | Tappan Ovens
Hoping someone can point me in the right direction. Oven won't light, but the stove top burners are fine. Don't smell any gas or any indication the oven is attempting to light....
next time send the brand name and model number so i can look up your machine,if it's a gas stove most likely it will be a bad ignitor,even if the ignitor glows it still could be bad,if the flame doesn't ignite and the ignitor is glowing change it out,if it isn't glowing pull out the ignitor and check it with a meter,common problem.
May 07, 2011 | Ovens
Stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I have an Amana AGR5715QDS and when I turn it on and set it for any temperature, lets say 350 degrees, it does not turn on or heat up. The stove top burners still work fine and the door appears to be OK,...
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 05, 2010 | Amana Ovens
My tappan gas oven (Model # 30-4942-0005) doesn't light
yes the igniter is not calling for enough amps to open the control valve, the igniter needs to be repalced.
Feb 01, 2010 | Tappan Ovens
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
Gas oven not heating, stove top working
Is your stove electronic ignition? Can you here the ignitor clicking as it trys to light? If so the gas valve on the back of the stove for the oven has failed and is not letting gas to the burner. If you smell
Jul 04, 2009 | Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Ovens Logo
729 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
