Posted on Jun 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can see print queue but it wont print - Lexmark Office Equipment & Supplies
Anonymous
Level 3:
Master:
  • Master 638 Answers
  • Posted on Jun 03, 2008
Anonymous
Master
Level 3:
Master:
Answers
638
Questions
Helped
223182
Points
1485
  1. FIRST TRY TO CANCEL ALL THE PENDING DOCUMENTS WHICH YOU HAVE GIVEN BEFORE THEN TRY TO PRINT IF THIS DOES NOT WORK THEN TRY OTHER OPTION GIVEN BELOW.
  2. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  3. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  4. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  5. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  6. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  7. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  8. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE
HP C7280 wont print custom size card stock 7.25 x10.25 wont feed or paper jam, however will print when fed on the left side but no guide to keep paper straight. how to correct this issue, Ive cleaned
Your question does not provide all the information necessary to absolutely resolve the issue. By now I suspect you've already resolved the issue or given up. Perhaps someone can use this info.
Need to know: Operating System (Windows 95/98/Vista/XP/7/8), Application (Word, Paint, Firefox, etc), type of job (jpg, pdf, text, etc.)
There is no short answer possible; but, I may be able to help with a generic answer. I can't help on Apple but I suspect it's the same as Windows, (and Unix, Linux, OS2, etc.).
Provided the Printer works proper on normal 8 ½ x 11 stock (print media) then it is not a printer or Queue issue unless it is just confused. As a printer technician I have seen this resolved by rebooting the machine(s) and trying to print again. If that doesn't resolve the issue you need to know:
The application you send the print job from tells the Queue what stock (letter, legal, card, envelope etc) to expect. The Queue, a component of all versions of Windows, is created when the printer is initially installed on the computer. The Queue holds print jobs and then sends them on to the printer when the printer tells the Queue it is ready. Some applications are more robust allowing more options than others. However, printing from inside a browser is frequently sketchy. If you're printing from an application that is different from the one that created it you may face an issue of the printer not getting the correct stock information.
Very Important: First before you attempt to send the print job check the settings in the app to insure your job has the right paper stock selected. Then, as you prepare to send the job from the app to the Queue before you hit the final "Print" button, check the "Paper Source/Size/Media" boxes in the "Printer Properties" to make sure your sending the right stock information. If that doesn't fix it; try to save your project in a format readable by another application and try to print it from the other app.
Note: 1. Print jobs are served to the printer by the Queue one at a time on a FIFO (First In First Out) basis. Sometimes print jobs get hung up in the Queue. A hung print job will block all subsequent jobs until the hung job is cleared. When a print job is sent and nothing happens (no printer activity or error messages on the screen.) look in the System Tray for a printer icon. Open it up and see if there are any jobs hung. If so cancel them and start afresh. This may require a reboot.
2. Print Queues can (rarely) become corrupt and must be deleted and rebuilt.
There are still variables too numerous to mention.
You can get HP Support at
HP Photosmart C7280 All in One Printer support
Whew! I've never tried to help resolve this issue in a post. Good Luck!
1helpful
So far answers don't coincide with the directions I've been given, which is "Press the WSB Button for 5 seconds."
The print queue is what is locked up. Try deleting the items in the print queue.
Start by pausing the print queue. Then delete the items in the queue one by one.
When you have the last print job in the queue it will probably be jammed up in the transition between the computer and printer. Switch off the printer. This should cause the printer on the computer to become offline.
Try deleting this job abain. If it dissapears then turn the printer back on making sure the computer understands the printer is back online. Then try printing again.
If it does not dissapear then you will need to restart the computer to free up this job. When the computer is back up and running check the print queue again. If the job is gone then turn the printer back on and try printing again. If it is not gone then try once again to delete the print job and it should dissapear this time.
Once the job is gone and the print queue is empty turn the printer back on and make sure the computer understands it is back online again.
How do i clear print queue , document says deleting but wont finish
go to start-in the run or search box-put in services.msc-hit enter-look for print spooler-left click on it-hit stop-then hit start or restart.
restart pc or go back to printers and faxes cancel print jobs stuck in the queue again.close printers and faxes and open it to check if queue already cleared up.that should do it.
Document in queue wont print or delete
Click on the link below and follow the steps mentioned.
Clear Print Queue
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
The arrow light wont stop flashing
this is common issue when paper jam or errors in printing queue,, check for any paper stuck inside (open up the back bay) delete the printing queue, power off printer restart the computer ! you should get solid green light
4helpful
My documents wont print straight away,they go in a queue. why is this?
The printer is paused. On windows print queue window check the printer menu and make sure "pause printing" is not selected.
1helpful
2answers
Canon iP1880 printer wont work
Check to make sure the application your printing from isn't defaulting to the manual tray...if so the printer will just sit there until you load the manual tray.
One other thing to check is if he Print job you are printing, is it actually getting to the Printer? Open the Printer so you can see the Queue, and then print something. If the printer is connected properly you will see the document show up in the queue, if the document isn't in the queue, you have another problem.
Let me know and I'll try to follow back up
Erase queue
Stop and restart the print spool service through the services console.
Start > Run > Type services.msc
Press ENTER or click OK/RUN
Locate the Print Spooler service.
Stop the service.
Restart the service.
Now troubleshoot your printer issue.
"Superhiway"
Canon 4150 wont print , goes into queue
Have you gone into the queue and deleted the print jobs and started again? Do you have any error lights? If so there could be a hardware problem with the printer.
Try taking out the toner and putting it back in. Sometimes that will force the printer to reset intself.
If that doesn't help then you may have to delete the printer from the system and re-install it.
My 1205 hp printer wont print because of an error in the queue
sure..you can do this by unhooking the printer, shutting it down, then turning on again..in meantime, you'll need to restart your computer too
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
