Question about Frigidaire FRT18G4A Top Freezer Refrigerator
Not cooling Power went out. Went to fridge next morning everything was thawed out and no longer cold. Light works, but it's not cooling. Unplugged and plugged back in. Still not working.
  • Frigidaire Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
Refrigerator part not keeping cold- freezer freezing. I unplugged it . Cleaned the freezer and thawed it out. It seems ok but the refrigerator part is not cold.
There is a fan that delivers cold air from freezer to the fridge section. if freezer is working fine, and fridge part is not cooling replace the fan motor/fan
Dec 29, 2016 | Refrigerators
Why are my fridge and freezer to warm?
Sounds to me like your freon is low. That is the gas fridges use to cool things down.
I may be wrong but I would get a repair man to check the freon pressure first.. Low freon is caused by a small leak in one of the lines or in the compressor its self. I had an old fridge and the freon went low just over time.and had to be topped up.
Jan 13, 2015 | GE Refrigerators
Fridge temperature too hot won't go down with temperature controls
This looks like there is a problem with thermstat in the fridge. We had a fridge that would not cool and we found it to be the thermastat problem. You have to replace the thermstat on the fridge. Not 100% sure but a high possibility.
Mar 23, 2014 | Frigidaire Refrigerators
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Wii completely stops working after power outage
I just had the same problem as everyone else. I had a brief power loss and our new Wii system's power would no longer work. To fix the problem, I unplugged everything from our Wii and unplugged the power cord from the outlet. I let the system set for 10 minutes and re-plugged the power only. That did the trick. Then I was able to plug everything back up and we are now back to playing.
Supposedly, doing the steps above resets the Wii according to the Nintendo online trouble shooting guide.
Sep 28, 2008 | Nintendo Wii Console
GE Fridge/freezer not working properly!
hey ur thermister has worn out may be due to the power surge when the power came back at that time so change the thermistor then check it out.........
Sep 09, 2008 | Refrigerators
Refridgerator is not cooling properly
Ours does this too; it says its 34 degrees but really its 53-58 degrees. . . The compressor coolant part of the machine freezes and then it can't circulate the cold air to cool the fridge. You have to unplug it for at least 24 hours to let it thaw, or you can take out the lower drawers and shelves, unscrew and remove the lower back pannel (from the inside of the fridge). We use a blow dryer to thaw out the ice block that formed on the unit. It goes faster if it is unplugged, this fridge is horrible we lost hundreds of dollars in groceries before we figured out the problem.
Dec 26, 2007 | Samsung Refrigerators
Frigidaire 7.5 cu.ft. Top Freezer the fridge part doesn't cool; freezer is fine.
It should be under warranty, retry he is probably right, run for 24hrs and it should work ok, if you ever defrost you should turn off for 24hrs and leave the door open. Regards Advisor
Aug 08, 2007 | Frigidaire GLRT83TES Top Freezer...
Frigidaire FRT18G4A Top Freezer Refrigerator Logo
127 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
