Question about Frigidaire FTF2140ES King Size Front-Load Energy Star Washer w/ Tumble Action
Water leaks from underneath washer - Frigidaire FTF2140ES King Size Front-Load Energy Star Washer w/ Tumble Action
  • blastplus Dec 21, 2008
    My Kitchenaid top load washer clean and runs fine, but covers my floor with water.
My washer is leaking with water on floor.it is now geeting worse. the washer seems to clean fine. my floor is gettig ruined please help
Posted on Oct 06, 2008
jsrock516
  • 5911 Answers
SOURCE: washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
Posted on May 12, 2007
SOURCE: Kenmore Washer Leaking from underneath
check the hose from the bottom of the drum to the drain. it probably slipped off. its held on by a tension clip. Someone must have pulled on the hose at the back.
Posted on Jan 22, 2008
SOURCE: water leaking from underneath after washer drains
I have the same washer and there is a white plastic piece underneath the washer where two hoses go into. It contains the impeller that pumps the water out. Anyway, on my machine this piece was incorrectly injection molded at the factory. The glue bubbled out causing an air bubble -- once the air bubble in the glue can stand the pressure and pops, the leak occurs!!!!! If you are a handyperson, take this piece out and use exopy to fix.
Posted on Mar 30, 2008
SOURCE: Whirlpool Cabrio Leaks Water
Good luck. Mine did the same and they sent their technicians out to fix the problem. A&E comes out and replaces the tub ring. They told me the washer is now made with the tub ring in place. When he opened the washer up I noticed I now have rust inside my washer. I have spent a month trying to get Whirlpool to replace my washer but they will only replace parts. A&E came out to replace the tub ring and now my door creaks and my washer does not go back together correctly. Hopefully you can justreturn the washer to where you got it. Read other reviews on line. It sounds like this washer is a lemon. Sorry!
Posted on Sep 03, 2008
  • 223 Answers
SOURCE: Bosch nexxt washer is leaking from underneath
All the things that greendude said plus check the seams inside the drum as if these have even slightly parted it could cause the leak you're describing. Good luck.
Posted on Sep 26, 2008
Water underneath unit?
Check your water hoses may be leaking behind the machine or at the tap.If the hose is leaking turn all taps off. the alloy crimp needs to be cut off & put a hose clamp on the hose.turn all taps off when machine has finished the wash.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
My washer is leaking from underneath the machine. What is the cause?
It could be a few things, a hosehas a hole in it, the water pump is leaking , or the cenbter seal on the transmission is leaking. Best way to check is to put some water in it, have someone help you lean it back and look underneath to locate the leak. If the water is leaking only in the agitate cycle and not as its filling then its your center seal.
Nov 03, 2010 | Kenmore 23822 Top Load Washer
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
There is a little bit ofwater leaking from underneath the washer.
The bolts on the drum case are probably loose.
Remove the rear cover to access to bolts
Jun 23, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer is leaking water from underneath. How can I fix this problem
Are you sure its from underneath as a lot of washers seem to be leaking underneath but its actually a blockage in the soap dispenser. Or the water pressure is too high and splashing out of the dispenser in this case make sure the m/c is level front to back.
Mar 07, 2009 | Roper RAS8244KQ Top Load Washer
Water leaking from underneath after washer drains
Hiya........... have a good look at the door seal for any visible tears... do it with wet hands... and the electric off!! If you cant see anything... Have a look at the pump couplings.. for any visible signs if leaking!
Get back with the results
regards Faggly
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer leaking water from underneath
May 11, 2007 | Kenmore 44042 Front Load Washer
Open Questions:
See all Frigidaire FTF2140ES King Size Front-Load Energy Questions
Washing Machines Logo
273 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
