Question about Amana AOCS3040 Electric Single Oven
F1 error on SS Amana Convection wall oven
We have a recurring problem where the console beeps and flashes F1 continuously until we disconnect the power. The code apparently means there is a faulty control but we can not find out what parts need to be fixed / repaired. Any suggestions?
Thanks
Kathy
  • 725 Answers
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC
Posted on Jun 04, 2008
I am having the same problem. What parts do I need if it's the EOC or control?
Posted on May 17, 2010
2 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: F1 error on SS Amana Convection wall oven
hi in the amana fault codes it says to replace the clock.its faulty thanks
Posted on Oct 16, 2008
F3e2 error
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
AOCS 3040WW convection oven
F1 Error code for Amana indicates a failed electronic range control (ERC)... that's the main computer behind the keypad. Post back with the exact model number and I'll assist with part number and replacement procedures.
Aug 29, 2007 | Amana AEW3530DD Electric Single Oven
F1 code GE profile convection self clean wall oven (95?) oven beeps F1 code oven works when it is on bake etc. when touch key are pressed it goes off but starts to beep again
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Sep 19, 2011 | Ovens
F1 flashes even after changing control panel
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 27, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
F1 alarm started last night. Turned off circuit breaker overnight, tried today and still continues to alarm. Repairman wants $76 dollars to walk in the door. Please help
Hi.
The error meaning depends on the oven brand.
On Amana and other brands F1 is a faulty control pad or faulty electronic control.
That may be your case , since the electronic control looks being jammed.
Try tripping the circuit breaker for two minutes (or disconnect power cord). If that does not help, then call the manufacturer at the number listed on the owners manual.
Note: on other brands F1 indicates incorrect temperature , and is associated with a faulty temperature sensor. This normally does not cause the electronic control beeping and not responding.
Nov 15, 2010 | Amana AOES3030 Electric Single Oven
F1 message flashing, annoying beep in the middle of the night
you could have a bad touch pad or ECU which is the main control board.
Sep 16, 2009 | Amana AOCS3040 Electric Single Oven
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
The control panel has a design problem, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the panel out, and inspected it. I found a web solution that said to shim the panel out away from the housing slightly because it rubs on the metal housing around it and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried it, and it still did not work.....panel was still beeping. Mine seemed to be the timer control buttons that were going on and off. So, I took it out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off and looked at the control panel. It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and put the cover back on the board. It was still sticky enough to go back on. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo!
Oct 16, 2008 | Amana AOES3030 Electric Single Oven
Amana Convection Oven - Beeping Continuously
F1 code and continuous beeping. This is a common problem with that type of Amana control. The control panel has a design problem I think, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the control panel out, and inspected it. I found a web solution, that said to shim the control panel out away from the housing slightly because it rubs on the metal around the opening and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried that, and it still did not work.....panel was still beeping. Mine seemed to be the timer control that was going on and off, and then eventually an F1 error. So, I took the panel out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off....it is really sticky.......and looked at the control panel itself . It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and checked to make sure none of the printed circuit paths had any wear or damage, and then put the cover back on the board. It was still sticky enough to go back on, and stay in place. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo! The pic below is just an example pic from the internet. My model is slighty different, but the panel looks basically the same. 1_23_2012_2_51_28_pm.jpg
Aug 22, 2006 | Amana AEW3530DD Electric Single Oven
Amana AOCS3040 Electric Single Oven Logo
710 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Joseph Hoffmann
Are you an Amana Oven Expert? Answer questions, earn points and help others
