Question about Whirlpool Washing Machines
I have a whirlpool wasing machine and the water stop light keeps coming on and the machine wont do anthing just seems like its draining all the time
  • 868 Answers
Model number ????
Posted on Jun 03, 2008
My whirlpool washing m/c 1400rpm awo/r 5406 will not complete the wash cycle it washes until it gets to spln and drain then the service light comes on (spanner)washer stops working but water still flo
locate the dranage water pump, screw it ou nd clean or check on the filter cuup,,always situated next to the water pump below,,u can trace the pump along with the outlet
drainage tube
Jan 26, 2015 | Whirlpool Washing Machines
Leaks water only when wasing or draing cycle ubder front of machine
Look for a leaking hose on the pump housing. May be just a loose clamp.
Jun 27, 2017 | LG WM2077CW Laundry XL Front Load...
My whirlpool front loading washing machine keeps stopping before the rinse cycle. I've cleaned the filter and the drain hose as well as all the inlet hoses. It stops and all the lights flash and it wont...
While it stops to rinse , does it drain off? if not there is block on the drain valve and so there is an error on the board because the water level sensor has to switch OFF and then ON to confirm that water has come in for rinsing.
So if the cycle is absent the possible fault can be the program controller. So you need to check the actions when the fault occurs, check for drain,.then after drain the inlet valve must open to allow water and then the water flow must cut off to start the motor.
If there is no action and output then the controller can be defective.
Apr 12, 2011 | Whirlpool Washing Machines
My washer is full of water that wont drain and keeps saying "sd" and "ld" and wont let me change cycles..
Your machine is taking too long to drain. Check the outlet, pump inlet and filter for obstructions. Press STOP/CANCEL to clear the display.
Feb 17, 2011 | Whirlpool Washing Machines
Wasing mechine does not stop spining after draining water &keeps spining ,does not stop automatically untill i stop manually eitherby opening the lid or pulling the knob
You need to replace the timer switch on your machine. If you will post your Maytag model number I can direct you to the part you will need.
Happy Holidays
Dec 13, 2010 | Maytag Washing Machines
Whirlpool washing machine wont stop all lights
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out.
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
How abt a nice rating for the free help? Thnks
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Whirlpool washer AWM 5145/5 water wont drain/stops on B
I had same problem twice, the first time there was a sock in the filter at the front adjoining the pump, the second time a sock had got in the pipe under the drum which is more awkward to get to but is possible if you have the tools to remove the back plate and are ok at diy, there is a spring tension clip on the pipe which comes off quite easily with a pair of pliers.
Jan 14, 2009 | Whirlpool AWM5145/2 Front Load Washer
Washing Machines Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
