I have just changed the batteries in my keyboard and it will do nothing. It is as though it is no longer connected to my computer. How do I reconnect? I am using a diffeent computer to get this help.
  • 871 Answers
Have you tried using your wireless keyboard on another computer? sounds like the fresh batteries isnt the reason but it may be something with your keyboard. try to use it on another computer and if the problem goes away, you might want to do something with your computer to remedy the problem... load drivers.
Posted on Jun 03, 2008
Why does my brand new, just unpacked wireless Logitech wireless keyboard and mouse (unit mk550) doesn't work? When I received the unit, both off/on switches were on. The keyboard was 'dead' nothing
You can change the batteries, then push the connection button on the back of the keyboard, also, download the logitech software to help get it set up.
Jul 03, 2014 | Logitech Computers & Internet
Wireless mouse pa3706e-1et1 no longer operates my computer even though new battery installed and software re-installed.
Aside from the fact that the mouse may have gone bad, have you tried pushing the "connect" button on the bottom of the mouse? Also, is the battery in correctly?
Change the USB port to see if that helps.
May 19, 2011 | Toshiba Wireless Mouse PA3205U-1ETC
The keyboard doesn't work, even though I just changed the batteries. Now what?
>when wireless keyboard or mouse runs out of battery, you need to re-establish the bluetooth connection in order for them to be functional again. To do so, you need to press the connect button on the keyboard and the USB dongle connected to the computer at the same time for about 8-10 seconds to establish connection. After that, you can try typing again. Same thing applies to wireless mouse.
Oct 03, 2010 | Gear Head WIRELESS keyboard/Mouse
Wireless mouse stopped working.
Unplug the wireless receiver from the back of the computer. Wait 10 seconds and replug back in. Check connectivity. If nothing then check batteries in mouse, if still nothing try click the Connect button on the wireless receiever and then underneath the keyboard...repaet the process for the mouse. You should get something on the screen stating the channel 1 is for the keyboard and channel 2 is for the mouse. Hope this helps! - Erick :-)
Dec 19, 2009 | Microsoft Wireless Laser Desktop 4000...
My dell keyboard with blue tooth connection
If there is no light on the Bluetooth keyboard it means there is a problem with it.
If the Bluetooth keyboard is not responding try to do the following:
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Keyboard
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth keyboard will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
Nov 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My keyboard has stopped working. I have chaged
Get another one then, cause it seems that the receiver either changed channels or broke in some way
Sep 27, 2009 | Microsoft Wireless Optical Desktop Comfort...
Keyboard wont connect
Hello
I've had the same problem with the Keytronic stuff. Most of the time new batteries solve the issue. Once, though, batteries didn't help. I discovered that if I wiggled the batteries it would work. I tried an old trick. Using a straw, put a drop of Coke on the connections. Scrub the area with an old toothbrush. If there's residue use rubbing alcohol to remove it.
Good Luck
Sep 24, 2009 | Logitech Computers & Internet
Wireless keyboard is blinking a blue light but nothing else is working
Normally Dell keyboard require a wireless uSB plug in that connects to your computer and there is usually a small button on both the keyboard and the end of the connector. Press them both. Normally preplacing batteries causes the connection to be disrupted.
Mar 14, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
Mouse
Do not use a mouse pad with this mini mouse. Battery will last much longer. I have had this mini mouse for about a year with no problems. Recently, though, after changing batteries, I found that the USB connector fails on and off. I have to pull out the USB connection and put it back in again. However, I am having to do this several times a day.
Oct 30, 2007 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
