Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water dripping from freezer
I have a whirlpool refrigerator model et1mtkxkt02 drain tube in freezer freezing up do u have a fix for that
    Scholar:
  • 148 Answers
A quick fix I found is to hang a peice of copper wire from the defroster bar in the freezer and let it hang into the drain tube when the defroster bar gets hot it heats the copper to prevent the freezing,but the thing you should do is check the resistance with an ohm meter across the defroster bar,if its ok its the defroster assembly located in the fridge
Posted on Jul 07, 2008
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
Drain tube opening clogs with ice inside freezer.
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com and provide your full name, phone number, address and the model and serial number for your freezer.
Apr 01, 2017 | Whirlpool Freezers
Water dripping
YOU MIGHT HAVE A FREEZER DRAIN TUBE FREEZING UP AFTER DEFROST AND BACKING UP IN FREEZER MAY NEED TO BLOW OUT DRAIN AFTER YOU DEFROST AND EVEN PUT A WIRE INTO DRAIN WRAPPED AROUND DEFROST HEATER TO HELP KEEP IT FROM FREEZING UP. THE WIRE WILL DRAW HEAT INTO DRAIN WHEN IT GOES INTO A DEFROST CYCLE
Dec 02, 2011 | KitchenAid Refrigerators
Water is leaking inside of the refrigerator on the (if you are looking into the fridge) the left side. I cannot tell where it is coming from - i see no dripping from anywhere but it sits in puddles on the...
I have a Whirlpool Top-mount refrigerator. Whirlpool also manufactures many of the Kenmore refrigerators.
A few weeks ago I noticed a puddle of water on the top right shelf in the refrigerator section. I figured out that it must be the water that forms during the defrost cycle and normally drains down through a tube in the back into an evaporator tray beneath the refrigerator. Something was preventing the water from draining away and instead it was dripping through the overflow holes from the freezer into the refrigerator section.
I emptied the freezer and took off the back panel. It actually wouldn't come off at first because all the water beneath the defrost heater which should have been draining out the drain hole was frozen into one solid block of ice. I used a hair dryer to melt the ice (took a while - be patient) and then took off the panel.
To melt all the rest of the ice in the drain tube I used the hair dryer. To clear out the ice in the drain tube, I used a turkey baster and kept putting down hot water until I heard water making it down to the evaporator tray beneath the refrigerator.
The following mod is "try at your own risk" (I wouldn't do this if you still have warranty coverage - call a tech instead):
I made this modification to prevent the problem from recurring (at least that's the hope): Wrapped a piece of wire (unbent a large paper clip) around the defrost cycle heater and stuck it into the drain hole. The theory is that the wire will heat up every time the defrost cycle runs and will keep the drain hole from freezing shut.
One thing I noticed during this repair concerns the drip pan beneath the defrost heater in the freezer (this is the pan that collects the water that is melted off the coils during defrosting). The drip pan does not seem to be angled properly so that the water will drain normally towards the drain hole. I guess water could remain behind then freeze later. I reported this to Whirlpool.
Mar 19, 2011 | Kenmore 64802 Top Freezer Refrigerator
Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Jul 08, 2009 | GE Refrigerators
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Leaking water inside fridgerator
You need to manually defrost then let sit over night .Pour warm water down the drain hole if does not go down fast than you will need to clean drain tube out with wire start at the rear of the unit and there will be a drain tube going in the drip pan good luck :)
Sep 10, 2008 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
Loud banging noise and water leaking
first of all the noise is the internal compressor motor hitting the steel shell on shut down. in my experience this is annoying and not really a huge concern as far as the compressor dying any time soon. now your drain problem. i would recomend the wire or heat probe that whirlpool recomends. when your freezer defrosts the water that drips off of the coil can and will flash freeze in the drain area causing it to freeze up a peice of 10 or 12 guage solid copper wire run into the drain and wrapped around your def heater will transfer enough heat into the drain hole to prevent it from freezing up.
fwiw: whirlpool in my opinion is probably one of the best appliances on the market..
Dec 12, 2007 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
159 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
