Question about Cooktops
Viking Gas Cooktop - Ignition sparks continuously when in 'on' position
Repairing my Viking Professional gas cooktop - 6 burner model. The leftmost front and rear igniters will not stop sparking if the gas is on, even after flame is produced. The other four do not have this problem. Any thoughts on the source of this? I just replaced the ignition module today to solve another problem.
  • 3 more comments
  • Chasencsu Jun 18, 2008
    Same problem, but haven't found out how to fix it. Any luck???
  • Anonymous Jun 20, 2008
    Same problem!
  • RMZ1 Dec 27, 2008
    Problem did not occur continuously, but wanted to correct. Obtained the module from a Viking distributer, but problem only got worse. Replaced the module several times. Finally put the old one back. At least its intermittent with the old module. Any Ideas?
  • kelp93 Mar 23, 2009
    GE Profile Gas cooktop continues to produce sparks when plugged in even though I do not turn on the ignition switch. This happened after I cleaned it and I suspect some water got into the ignition switch.
  • Anonymous Mar 14, 2014
    I don't know if this is a do it yourself project. One igniter (the main one) is not sparking. All of the other 4 spark. Is this an easy fix? I'm thinking it isn't.
This is likely caused by either a dirty ignition electrode, a cracked ignition electrode, or a bad spark re-ignition module.
Clean and inspect the six electrodes for cracks, If that doesn't solve it order a new
Ignition module from an internet appliance dealer that carries Viking parts like Appliance Zone.
If you replace the Ignition module yourself, make sure to turn off the circuit breaker to the range/cooktop before you work on it. Also, make a drawing of where the different color leads are plugged into the ignition module before you unplug the wires and plug them into the new re-ignitor. If the unit is under one year, this should be covered under the warranty.
Viking had a recall a few years back on their ignitor modules.
Posted on Oct 27, 2008
    New Friend:
  • 12 Answers
Try cleanning out the spark ignitor with a wire brush, and moving the ignitors. this has worked for me in the past. must have to do with conductivity. I had the same problem, changed out to new spark modual, and changed back to old one and clean out spark ignitors.
second thing is, check for any points where the electricity can jump, and tape it with electrical tape.
Posted on Apr 22, 2013
One of the switches is shorted out. This is caused by cleaning the knobs. The holes still have water in them and it runs down the shaft when they are replaced. Usually the switch is just mounted on the shaft of the gas valve. Disconnect the wires and re attach them one at a time to see which one or both are shorted out. Replace t he defective switch.
Posted on Jul 07, 2008
Is there a specific regulator for a Viking D3 cooktop or can I purchase one off the shelf?
If it runs on natural gas it has a lower pressure regulator than one that runs on propane gas. Nat gas is 1.1kpa propane is 2.75kpa
May 03, 2014 | Viking D3 RDGSU2605B 36" Gas Cooktop with...
The Viking gas stove - 6 burner - clicks constantly -- it won't stop. it has done this for years and usually goes off after a while but now it wont stop clicking. The burner that is not even on click.
The problem is one(or more) of the 6 switches that turn on the spark when that burner is turned on is shorted and stays closed (on) all the time.To determine which one it is the front face has to be removed,with THE POWER OFF a meter set to low ohms rating is used to check each switch by removing the wires to it and see which one has continunity (ZERO OHMS) when its off and that switch that slips on the burner valve shaft is the bad switch(s) and needs to be replaced to keep it from sparking all the time.
Please note though, in a perfectly working cooktop all burners spaks at the same time and only the only one that has the gas flowing to it will ignite,that part is normal.
I hope this helps you to repair your cooktop,
Gene
Aug 08, 2011 | Viking Professional VGRT362-4G 36 in. Gas...
A spark that causes a snapping noise when a burner is turned on.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 26, 2010 | Viking 31 in. VGSU101 Gas Cooktop
How do you replace the ignition module on stove.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 14, 2010 | Viking Professional VGRT362-4G 36 in. Gas...
I hav a Viking professional. Only one burner ignites.
heatman101
Mar 18, 2010 | Viking 42 in. Professional Series...
Viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
Viking gas cooktop vgsu161-6b sparks continuously. There is no gas leaking. I spilled water on the controls and it is only when I turn on the 3rd knob from the top that this happens.
The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry though no permanent damage has been done. Leave it unplugged from the electrical outlet for a day or two until the liquid dries out. You can manually light the burners with matches or a BBQ lighter in the meantime. If you want to try and speed up the drying process you can use a hair dryer.
Oct 20, 2009 | Viking 37 in. VGSU161 Gas Cooktop
Viking 30" gas professional series cooktop sparking problem
And before that Most likely one of the ignition switches (they are under knobs) got shorted possibly due to spilled liquid or a cleaning stuff sprayed on. In that case it should stop sparking after a switch drys. Still no go replace the spark control unit.
Thanks
Kindly rate the answer
Kevin
Jul 06, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
Nov 25, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Cooktops Logo
3,327 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
