FixYa.com
Tags:
Panasonic Workio DP-190 Multifunction Laser Fax Machine DP190, D-P-190, D-P190: DQ-UH35... Printer
Error 870
posted by jennlrad on Jun 03, 2008
when faxing, error message "memory full" and code 870 pop up. what should i do?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 03, 2008
Not Rated (0)
waynechurch
Rank:Wiz Wiz
Rating: 83%, 122 votes
It seems to me that when you are faxing, your machine is probably set to save the fax to memory. If this is the case you should just have to delete whatever has been saved, through the control panel menu.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Printers problems?
Printers
I want to print envelopes
I want to print envelopes in a... Answer This...
Printers
says i'm out of color
says i'm out of color ink. I... Answer This...
Printers
error message: print head not
error message: print head not... Answer This...
Panasonic Workio DP-190 Multifunction Laser...
panasonic workio DP 190...
help me load my printer onto... Answer This...
Panasonic DP-190
After new cartrige installed,... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
