You are going to need a paper clip. Look fo a small hole next to the switch. straighten the paper clip and put it in the hole in the center. carefully push to activate the mechansium to open the door. Then you can troubleshoot the door. Turn off the computer then pull the power cord from it. Open the computer case find the power cable to the cdrom/dvdcdrw and push it in to make sure you have good connection. If it still doesn't work after this then you can get a new drive for less than $30.00 (usd)
to be honest, the X1700 is a weak computer, you should NEVER buy slimline desktops, the power supply is going to cost more than the computer, being that it is a special type, you cant just buy it in a store, having to replace some myself, i can tell you that a decent used PC is around $150, and you can still put some of the hardware from the slimline into the used PC such as the hard drive, cd drive, and memory. Best of all, a full sized unit can be fixed relatively easily and for a lot less since most parts are interchangeable
Check out above under "Multi-media", you have (4th bullet and 7th bullet) 'audio input and output jacks' + '2 stereo speakers & subwoofer'.
Might want to tell a good service center about that sound issue since
a NO SOUND problem might indicate not only 'bad stereo speakers' but
since you have a sub-woofer, that circuit might have blown (along with significant parts of your output audio).
You can set the receiver to any source that uses a optical connection. Then make sure that whatever you select whether it be CD/DVD you also have the source connection set to optical too on the receiver setup menu.
That being said, after that is done you will need to set up the computer to output audio. That usually just involves changing the output mode on the computer and adjusting the levels...open the Acer audio managment application, choose the audio output mode to stereo or dolby digital and turn everything up on the computers level controls. Then, when you open whatever software you're going to use to play your discs you may also have to adjust the volume level there as well.
connect both the mouse &keyboard restart the machine.if then also it not works then there must be some hardware problem&your desktop does not support.try the usb mouse&keyboard.
It's usually the green plug that you hook up speakers to. If you look closely at the sound card area of your computer, you will see little pictures telling you which one is for the mike, line in & speaker.
