Question about Whirlpool WFC7500VW Washer
Error f06 is displayed - Whirlpool WFC7500VW Washer
Drive motor tachometer error, check the shiping bolts are removed, run quick diagnostics to check motor system, unplug washer and check wire harness between drive motor and motor control board and then between ccu. plug washer in and try cycle.
Posted on Mar 07, 2011
Can anyone tell me what F06 error code means on the whirlpool 6th sense 10kg washer? and what to do about it as the screen is flashing but the door to the machine is locked. Thanks
F06 Drive motor tachometer error This error occurs when the main control unit fails to detect the motor speed from the tachometeric generator fitted to the motor either through an incorrect resistance or the tacho is not correctly fitted into place. The machine will try to detect the reading several times before aborting the program ans shutting down with this error being displayed.
When checking ensure that the drive belt and belt tension are okay as this can cause this error.
  • Check tacho resistance
  • check tacho placement
  • Check wiring for shorts
  • Check wiring harness connections between motor and main controller
  • Check drive belt for damage and tension
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
May 26, 2015 | Whirlpool Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
I have a whirlpool wfs1276aw. It suddenly stopped working displaying the error F06.
pl.check the current and voltage with the meter and continuity test after unplugging the mains chord,which may give some iferrence
Dec 02, 2014 | Whirlpool Washing Machines
Flashes error code F06
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its a faulty CCU that needs to be replaced. Here is the part.
Oct 19, 2012 | Sears Kenmore Elite 4.2 cu. ft. Front-Load...
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite is giving me F06 error. Any
"F06" is a Motor Speed Error. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Read through the link provided and let me know if you have questions. In most cases this problem is attributed to a tachometer failure on the Motor Control Unit (MCU). If the this is the case, the MCU must be replaced.
If you require additional assistance, let me know. I hope you find this information helpful.
Aug 31, 2009 | Kenmore Elite 45986 Front Load Washer
F06 and F14 error codes
Before you replace the control panel use a tester on the cable to check continuity .. if the cable is faulty you will get this fault
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F06 error
Unplugging it sometimes corrects the problem. However, it must be unplugged for SEVERAL minutes.then start it again i think it ll set it ok becuase sometimes it all sets it right.
or
If all checks ok, then its like a faulty CCU, check your owners manual, some are covered under warranty for up to 5 yrs.
now check the CCU,MCU and Motor any one of these must be faulty that will only lead to F06 error.
Jun 19, 2009 | Kenmore 45087 Front Load Washer
VCR shuts down automatically after displaying the error code F06
Your vcr seems to use the K Mech. F06 Means that the mechanism locks after unload.
The cause of which might be the loading motor or the carriage alignment.
Apr 13, 2009 | Panasonic Televison & Video
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool WFC7500VW Washer Logo
310 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
