Question about IBM (73P0544) Motherboard
IBM Netvista PC not getting power on
When I switch on the power button, my PC do not respond
SMPS is OK switch on/off is also ok
but the point where it gets plugged in on motherborad may be a problem.
what to do?
vikas
  • T&N Family Electronics Dean and Sherrie Terrell
    Do you have a way to test the power supply? Test the power supply and see if it is putting out the full power. Is there a light on your motherboard to let you know that it has power. What is,
    SMPS is OK. I have no idea what that it. Do any of the fans turn on? How do you know if the motherboard is working?
  • 530 Answers
Hi! im josh may i help u.? Go to the switch connection of the motherboard and try to look at the short pins there it is just loosen connection.try to check also the red and white wire.change it if you have and extra one. hope i helped you. good luck
Posted on Feb 13, 2009
IBM 6794-75G IS NOT POWERING ON
Now please check the "smps" by another new or by your"smps" to another pc to confirm either it damage or not.
http://www.playtool.com/pages/psuconnectors/connectors.html
Hope this helps,
Feb 25, 2011 | IBM NetVista PC Desktop
I had to do a hard shut down on my ibm e machine because the visuals on the moniter were vibrating back and forth and the computer would not respond. When I turned it back on, i got no monitor signal and...
Hello there:
this beepiig generally is telling you that you are having
a problem with your video card what you can do is to unplugthe computer and open the case and locate the power supply cable that goes from the power supply to the motherboard and disconnect it
now press in on you power buttom and hold it there for 30 seconds and if you have a reset button do the same
now plug in the cord that you previously disconnected from the motherboard and than plug inthe computer and restart the computer and you should beok but if the beeping continuse than yes you have a video card that is failing you ok?
i hope that this has been very helpful for you
best regards michael
Nov 16, 2009 | IBM NetVista PC Desktop
Hi i have an IBM desk top machine this machine get off
To test the hardware all you have to do is to boot from a Linux Live-CD like
http://www.pclinuxos.com/  .
If all is ok there then your Windows is corrupted, reinstall.
Nov 02, 2009 | IBM NetVista PC Desktop
Nopaveron
1..mybe it POWER cable problem or
ur SMPS gone
so first change power cable than smps...
Mar 19, 2009 | IBM NetVista PC Desktop
I have ibm netvista desktop.when i reset biso time & date not chage.
Hi there:
when you are resetting the bios are you removing the battery from the motherboard and leaving it out for at least 30 to 60 seconds minimum please let me know there is still more that i can do to help solve this if needed ok?
best regards mike
Feb 18, 2009 | IBM NetVista A40 PC Desktop
BIOS BIN Files
I think Ur pc is ibm ok then go to the website and download for ur product bios and install .
ur in operating system download as exe file (or) download as iso image and then bootable for the bios in ibm.
http://www.ibm.com/support/in/en/
Check the site.
Feb 02, 2009 | IBM NetVista PC Desktop
I turn on my PC than half second turn off itself
It could be a motherboard problem, but, this may sound silly, but it could also be a stuck up power or reset button. I had this experience with a desktop pc where the power button got stuck in its "press" position. Try removing the connection of these switches from the mboard and use a metal screw driver to act as the switch by momentarily shorting the power switch connection on the board.
--you can also check the cmos battery of the pc. These newer boards would refuse to even power up if the cmos battery are drained.
Oct 08, 2008 | IBM NetVista PC Desktop
Model # IBM NetVista PC Desktop
when you boot hit pause when it gets to the screen just after the memory screen is finished. hit the pause button... it should say which key(s) to hit to enter setup.
Is there a bios password and you can't get past that ?
Robert
Sep 01, 2008 | IBM NetVista PC Desktop
IBM NetVista unable to bootup
This happens when the reset button inside is stuck. If the system is under warranty. Opening the case will void warranty. If it is out of warranty.... Open the cabinet and you can find a chunk of wires crowded in to a point on the motherboard. If you care fully inspect you will find a pair of pin (jumper pin) marked "RESET". If there is some obstacle that is shorting the contact, remove it and offcourse clean the dust particles or other material that could cause trouble. This should solve the problem
Sep 27, 2007 | IBM NetVista PC Desktop
Computers & Internet Logo
159 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
