Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Have a sony tritron wega flat screen tv and it wont turn on, its red light blinks three times, what is the problem and how do i fix it?
    Top Expert:
  • Sony Master
  • 74,383 Answers
Hello
Your TVs horizontal output stage is not working. That means, the line output side [LOT and related components], are inoperative. It may be due to some secondary missing voltages from the power supply section of your TV. There may be some open resistor, or short inside the Line Output Transformer [LOT] itself. Anyway that side is not working. Your TVs power supply regulator system has no trouble. It supplies the required voltage to the other sections. That is why you see the LED [Light Emitting Diode], fitted in front panel of your tv blinking for some time and shuts off. As soon as the TV is switched on, the power regulator system inside the tv will supply all the necessary secondary voltages to all sides. If at any section misses the required voltage, the system control Ic will detect it, and will try to rectify that. It is so programmed at the factory. If it can't do it, it will automatically shuts all the supplies from the power regulator system. It is a protection added by sony to all models of their Tvs.
You yourself cannot detect and repair this fault. Get the service of an experienced technician.
Posted on Oct 17, 2010
Sony wega tv
the deflection board has gone bad and needs replaced....sears will do it but charges alot.
Feb 07, 2008 | Televison & Video
My sony wega KDP57WS655 tv wont turn on...makes noise like it is coming on, clicks then turns back off and standby light is flashing
If the red light is blinking in front that sasy lamp. Your lamp needs to be replaced. They cost about $100.00 at your TV Fix It shop. Very easy to replace yourself
Nov 20, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
Tv light standby red just keeps blinking after replacing bulb
If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there.
Lamp cover is first thing that you removed from tv to replace lamp.
Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info.
Thanks.
Jan 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
TV won't turn on and standby light blinks 5 times
Replace This Diode: D647 ( Sony part number 6-500-567-01 ). Go to: http://www.encompassparts.com/tritronics// For parts. I will be here for future questions. Thank you
Jul 26, 2009 | Televison & Video
Red light blinking 7 times on Sony Triniton Wega TV
This means one of three things, either the lamp is bad on your tv, the ballast that powers the lamp is bad or the safety switch for the lamp door is not depressed or it has come un-plugged. It could also mean the power supply or fuse on the power board is blown. I am assuming this is a DLP tv, and if so, it is fairly easy to fix it or find parts for it online. If you are slightly mechanically inclined, want to save money and dont mind paying attention to detail then you can fix it yourself. If you need help dont hesitate to ask.
Jun 21, 2009 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Jan 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony wega and i get 4 blinking red lights
4 blinks code shows problem in Vertical Deflection section of TV. Of course it worth to be repaired. If you are not familiar with TV repair then call TV tech to fix it. And if you are tech person, let me know to help you out with tech info.
Jan 09, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
146 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
