Question about Mr Steam SUPER SERIES STEAMBATH GENERATOR MSSuper3EC1 Stainless Steel
I have a ms400E Mr Steam generator When I push the start button "on" outside the shower stall, It flashes on and off and I get an "err 2" message on the E-tempo contron in the shower.Nothing happens. What wrong? Power water and control wiring seem to be hooked up properly.
    Problem Solver:
  • 11 Answers
Hi my name is Mike I am with Mr. Steam please call our tech support team at 800-767-8326 we will need the model # and SN of your unit
Thanks
Posted on Oct 18, 2010
Can I manually wire around an in-shower control ? model sn 203834
Go back to where the generator is installed. You will see there is a grey control cable going into the right side of the generator where all the plumbing lines are. At the very end of the cable you will see there is a red, white, black and maybe a brown strand coming out of the end of the grey cable that goes into a molex connection that plugs into the side of the generator. Keep in mind where you see the red and white strand connected, which should be the two top female ports on the 4 port connection. Unplug the cable and take a metal paperclip or jumper wire and jump across the two top ports, keep the connection in place. This should cause the unit to fill and then produce steam. If it does, this could mean the controller has gone bad, possibly due to moisture damage. You can also remove the controller from the wall and jump the red and white wire that connects to the back of that controller just the same to isolate if the control cable is bad.
Feb 17, 2015 | Mr Steam Ms400e Steam Shower Generator
How do I repair an inoperable Mr. Steam steammaker
you can always have any local plumber or electrician call into Mr. Steam for on-site tech support. Otherwise if you would like to troubleshoot yourself please post symptoms and model number
Aug 12, 2014 | Mr Steam Ms400e Steam Shower Generator
Not enough steam
This may either be because you may not have the correct generator(either the wrong size model or the wrong voltage generator) or the heating element may be damaged, although this would be unlikely being it is a new generator. Go to www.mrsteam.com and size your room. Remember it is important to have the exact room dimensions AS WELL as material of the wall (ceramic, porcelain, natural stone etc) due to the fact that wall material is largely where you have all your heat loss and units have to be sized accordingly to the wall material of your shower otherwise you would surely end up with the wrong size.
Feb 11, 2014 | Mr Steam Ms400e Steam Shower Generator
Steam shower wont turn on getting a flashing temp on controller in shower
Hi I am with Mr. Steam Tech Support please call 800-767-8326 and ask for tech support. please have your serial number and we will be able at assit you in getting your unit up and running
Thanks
Mike
Mr. Steam
Product Support
Nov 14, 2010 | Mr Steam Ms Super 1e Steam Shower...
Mr. Steam won't start up
Hi my name is Mike I am with Mr. Steam Tech Support please give me a call at 800-767-8326 ext 1280 or email at mnail@mrsteam.com and I will happy to help you with your unit
Feb 19, 2010 | Mr Steam Mr. Steam Butler Package -...
Looking for local technnician to repair my Mr. Steam shower I live in Vienna Va
you can call the 800 number on your unit and thy would be able to tell you your nearest service center. Or you can log on to there web sit and go to dealer locator's, and ty-ip in your zip code. good luck I hoped this helped
Oct 17, 2009 | Mr Steam Mr. Steam Commercial Steambath...
Error code Prr on Mr. Steam control unit. Steam generator starts for about 10 seconds, but no steam comes out and error code "Prr" shows on control unit. Any insights?
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
Sep 15, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
Steam Shower shuts down immediately now.
probably scale build up from tap water unfiltered. Scale caused by mineral deposits will affect safety systems and auto cut offs in the unit
Sep 13, 2009 | Mr Steam Mr. Steam Commercial Steambath...
Mr Steam SUPER SERIES STEAMBATH GENERATOR  MSSuper3EC1  Stainless Steel Logo
264 people viewed this question
Top Mr Steam Electrical Supplies Experts
BJ Russell
Hippy_dd
Are you a Mr Steam Electrical Supply Expert? Answer questions, earn points and help others
